RB/BL Help me decide 1in or 2in?
Old May 10, 2004 | 02:52 PM
PoBoy's Avatar
More like all you 1inch guys were too scared to do a 2inch because you thought it was more involved and had to extend more stuff
GO 2!
Old May 10, 2004 | 09:03 PM
RobT2k's Avatar
Ok Rondo, you're on the clock, I've got my 2" kit on its way to me. I went with the grade 8 hardware and ultimate blocks just to be on the safe side. If I would have gone w/1" I probably would have just gone with standard. I don't want to worry about the BL when offroading. Hopefully the gap won't be too much and make my tires look too small, or I'll be forced to get a second set for offroad use $$$$
Old May 11, 2004 | 05:20 AM
shazaam's Avatar
There will be a large 2" gap .. and your tires will look small
here the solution. click here
Old May 11, 2004 | 05:57 AM
rondo221's Avatar
hehehe...
Hey Rob what size tires do you have right now? BTW Im leaning more towards the 1 1/2 inch BL
Old May 11, 2004 | 09:10 AM
  #25
Roadrunner's Avatar
If you have a TJM bumper up front with a 1" or 2" BL, what did you do about the gap left by the lifted body? Just leave it or is there some sort of Home Depot/Lowes rubber gasket thingy to fill in the gap?
Old May 11, 2004 | 09:14 AM
  #26
PoBoy's Avatar
With my 2inch...I just left it in place. It's not that bad:
Old May 11, 2004 | 09:15 AM
  #27
waskillywabbit's Avatar
Talking Gap
I have a 2" gap, but it's no big deal to me, it just gives the body room to flex without hitting the bumper. You can always get some custom mounts fabbed up to raise the bumper or drill the ones you got higher.
Old May 11, 2004 | 10:23 AM
  #28
sschaefer3's Avatar
It will adjust up with a 1" BL leaving around 1/2" to 3/8" gap.
Matched with a nice 1" adjusted rear bumper and fender covers from an early 90's Mini PU you can't even tell it has a BL.
Old May 11, 2004 | 12:15 PM
  #29
Roadrunner's Avatar
I'm very tempted to go with a 1" BL. My only concern is making it into and out of the garage, esp when lights are added. Currently, I have about 6" clearance between my roof rack and garage door. I'll be adding some Hella 500s, which I think will decrease my clearance to 3". With a 1" BL, I should have 2" of clearance.
I have to keep my 4Runner in the garage during the week since my wife needs her car to commute to work, so her car in the driveway.
Old May 11, 2004 | 12:21 PM
  #30
Talking Roof rack
Hella 500s mounted on the bottom of a Surco rack with the Surco mount brackets stick up about 2-2 1/2" inches above the top of the Surco. I have about a thumb width of clearance left
Old May 11, 2004 | 01:38 PM
  #31
Jackpot2's Avatar
2" for me. As RB would say ... "looks good"
Old May 19, 2004 | 05:45 PM
  #32
Roadrunner's Avatar
I forgot to ask, you guys with a TJM or aftermarket front bumper, did you remove the bumper to install the BL?
Old May 19, 2004 | 06:35 PM
  #33
934rnr's Avatar
My body-lift was already on.
While we are on the subject of bullbars www.4x4connection.com is having a sale on TJM's again it's $379 for a T-17 bull bar just FYI. I got mine from them back when they had them at $377.
Old May 19, 2004 | 08:16 PM
  #34
PoBoy's Avatar
Yep:
Any excuse to post a picture
Old May 19, 2004 | 10:30 PM
  #35
RobT2k's Avatar
Actually, I decided to just change the brackets on my bumper, so I sent the 2" back for a 1" kit. I'm really not a big fan of BL's so I figured the 1" is more like not even having one. Did you get anything yet Rondo?
Old May 19, 2004 | 10:35 PM
  #36
terky's Avatar
Hey maybe check one of these lifts out
http://www.truckperformance.com
They seem to be pretty cheap
Old May 30, 2004 | 05:10 AM
  #37
payyourtoll's Avatar
Originally Posted by waskillywabbit
Write-Up
2" Roger Brown Body Lift Kit: 2 Bumper brackets, steering extension spacer with 2 longer bolts w/nuts, longer bolts w/lock nuts for spacers, 2" spacers
Now put the bumper back on. Line up the bumper brackets on the front bumper mounts. This is where you need the 2" lift so the bumper will be close to the body again. The mounts on the sides don't line up after you raise the bumper, but I figure if someone hits you up front it won't matter anyway. These just seemed to be for extra support. I just put the bolts back where they came out so in case I need them for something later.
hey waskilly (or anyone else) - did you find that the bumper brackets were needed for the 2" kit to make things look 'right' in the front?
LittleUgly
15
Jan 2, 2020 01:30 PM
moparbay
Oct 6, 2015 09:24 AM
scott90
Oct 4, 2015 09:21 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
