Quick question.. cut the bump stops? OME Install today!
Old May 16, 2006 | 06:02 AM
rearviewmirror's Avatar
My OME suspension is being installed today, I just want to know if I should tell the shop to cut any of the rear bump stops down? It's a 2000 4Runner LTD 4WD, it appears to have the long connical bump stop inside the spring. I believe all the problems I have with this 4Runner is actually the excessively long bump stop causing a bottom out situation. So should I tell them to cut down the rubber stop a bit? If so, how much should they cut?
Thanks!
Old May 16, 2006 | 06:19 AM
Strap22's Avatar
Sponsoring Vendor
Thanks!
I would not recommend cutting. Your longer spring will help.
Old May 16, 2006 | 06:22 AM
Thanks! I just wanted to clarify! I'll post some pics later today when the install is complete.
While we're at it.. Can you confirm the which corner the trim packer goes on ? I thought it was driver front but now I can't remember. It was the one that came with your kit.
Eggslinger
Jun 8, 2019 03:32 PM
icentropy
Jul 11, 2015 07:21 AM
crashburnoveride
Jul 10, 2015 06:39 AM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
