quick question
Old Feb 11, 2004 | 01:20 PM
joeal's Avatar
quick question
how do i tell if there is spark coming from the spark plug wire?
Old Feb 11, 2004 | 01:23 PM
MTL_4runner's Avatar
Pull the sparkplug wire, put a sparkplug in it, hold it to ground (ie the engine block) and crank over the motor.
Make sure to always have it grounded when cranking....that is very high voltage!!!
Old Feb 11, 2004 | 01:26 PM
toy283's Avatar
A couple ways. If you have a timing light you can hook the inductive pickup to each wire and watch for flashing. A more effective way is to pull each plug one at a time and ground the casing to the head (just touch it to the outside of the head with an insulated pair of pliers and gloves). Then have a buddy turn over the engine and watch for spark. Don't do this for long, just a few seconds. With practice, you can determine strength of spark as well, something that the timing light method won't tell you.
jasonty
41
Dec 23, 2018 01:00 PM
thefishguy77
Aug 9, 2015 04:15 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
icentropy
Jul 14, 2015 10:23 AM
