Quick help needed. High beam wire?
Old Mar 5, 2009 | 01:47 PM
MillerPKA's Avatar
Redoing my wiring right now for the kc's up top and am fusing it into the oem fog assembly. long story short the factory wire splice is tapped into the low beam wire...the lights will come on only with low beams activated. I want to splice it into the high beam wire instead, thus all the lights coming on when i flip the highs on. the wire cluster is set back in there and set together all nice and neat so i'm trying not to test tap 30 wires. if anyone knows what color the high beam wire is please let me know while everything is out..it's getting dark soon! thanks guys
Old Mar 5, 2009 | 01:53 PM
Elton's Avatar
would it be easier to tap into at the headlight plug?
Old Mar 5, 2009 | 01:54 PM
MillerPKA's Avatar
no not the way the wiring is set up but now that you mention it i'm going back out to check and see if i can see the color wire coming out of the heads and pinpoint it from there. thanks and keep em coming for now!
Old Mar 5, 2009 | 02:02 PM
Yukon's Avatar
The highbeam wire coming out of the headlight is red green stripe, 99 limited.
Old Mar 5, 2009 | 02:03 PM
MillerPKA's Avatar
ok i've narrowed the 3 wires down that come out of the headlight. red/yellow, red/green, red/blue, the tap has been on the red/yellow so that leaves green and blue...any knowledge? i know it sounds easy to just check each one but its a whole different story when you're up under the dash
Old Mar 5, 2009 | 02:04 PM
MillerPKA's Avatar
righteous going to try now thanks man
Old Mar 5, 2009 | 02:06 PM
Yukon's Avatar
No problem, hope it works out
Old Mar 5, 2009 | 02:18 PM
MillerPKA's Avatar
ok well the red/green doesn't come through the firewall it's 2 red/yellow and a red/blue, i cut the red/yellow, turns out it was my corner lights, cut the other one and nothing happened. i'm confused but leaving it for now the nights coming in
Old Mar 5, 2009 | 09:05 PM
TheDurk's Avatar
I wouldn't expect the color at the headlight plug to match anything under the dash as that wire presumably dies at the fuse & relay box a little aft of the battery. I would also expect that the interlock between the fogs and lo/high heads is done there. Have you identified where the existing circuit is? If the light stalk is providing a ground to the dimmer relay coil only at low, there may not BE a wire under the dash that will give you the signal you want. If so, you will have to tap from the headlight plug or the fuse/relay box on the other side of the firewall. Hopefully someone with the wiring diagram can shed some light here.
Old Mar 6, 2009 | 06:18 AM
MillerPKA's Avatar
Thanks for the info, I'm sitting in my car messing with it right now if anyone has any information please deposit here, thanks!
Edit: Decided to take another route and got them working, thanks anyways
jasonty
41
Dec 23, 2018 01:00 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
luckypig44
Jul 19, 2015 11:25 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
