question about timming belt replacement
Old Jun 3, 2006 | 02:26 PM
J95runner's Avatar
hey guys i have a 99 4runner 3.4 with 112k miles on it. i am changing the water pump/timming belt on the truck. my question is, is that the bottom timming belt tensioner pulley has some play in it and i was wondering if it should be replaced. the top idler pulley has no play in it at all, and the bottom tensiour pulley i can see has some play between the bearing and the pulley itself, should it be changed while i am in here and have the truck all apart, the only reason i am hesitating id because now i will be out of a truck until this part comes in, thats the only thing i dont have. have you guys changed the pullies? thanks for your help
Jon
Old Jun 3, 2006 | 06:31 PM
MTL_4runner's Avatar
If it has play in it, I would change it on my truck. You don't want to go back in there a second time for a T-belt that broke cause an idler went bad.
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
Jnkml
Jul 6, 2015 01:20 PM
