Question about my 4 runner rear window problems / security
Old Jun 27, 2013 | 03:43 PM
Vargntucson's Avatar
Originally Posted by SpikeStrip
There is a TSB on this issue. It's a software gremlin in the ECM. See thread
https://www.yotatech.com/forums/f2/rear-window-has-gone-insane-86705/
I've attached the TSB there...
Simple solution is to press the "lock windows" button when you exit the car and problem solved... Or, you could fix according to the TSB, but that'll run you about 300 bux.
S.
The window lock doesn't work on my 99 4runner. My window goes down everytime I start my truck. I have to use the key in the tailgate when the truck is off to put it up.
Old Jun 27, 2013 | 03:54 PM
Originally Posted by Godzilla
if you lock the windows it will not stop the function of the remote switch. i just tried. as mentioned in the thread i posted in my reply try to disablle the switch first in the remote before you start opening the gate. i just opened up my remote, and you can either tapes something hard over the button, or completely remove the switch from the circuit board(dont know how so not recommending)
This may explain my problem. I have an after market remote but I disconnected it and it still goes down whenever I start the truck. I'm guessing a circuit is stuck open.
Old Dec 17, 2014 | 03:57 AM
rotorav8's Avatar
my window was doing this.
For some reason disconnecting the wiring on the rear hatch and reconnecting it reactivated the window. Maybe it reset the blue ECU? I'll be using the passenger window disabler for now. My remote does not have the option to roll down the rear window. It rolled it's self down in the middle of the night anyway.
I see a trip to the junkyard in my future. Thanks for all the help on this site.
4x4-runner
Feb 26, 2017 06:42 AM
voiddweller
19
May 2, 2016 09:10 PM
Corey
Jun 19, 2002 11:06 AM
