Question about CB install...
Old Aug 11, 2003 | 05:31 PM
StoryR's Avatar
Question Question about CB install...
Okay, so I showed everyone my pictures of it mounted. Today I decided to acually connect everything! It all went well, I just powered it with my Cig Lighter because it is dissconected anyway. Then ground it on the stereo mount. But my question lies within the coax. I really had no idea of how to hook the wires up to the antenna. I mean I know how, but which goes where. The coax has two wires sticking out, one white, one black. I figured the black one was the ground, so I ground it to at little extra screw on the side of the mount. And I connected the white to the antenna...Sorry for my ignorance, but is this right? The CB is powered and everything, but I have no idea if I am getting reception or not...Thanks for any help!
Old Aug 11, 2003 | 07:10 PM
NewToMods's Avatar
Interesting antenna cable. That doesn't really sound like coaxial cable?!? Coax cable normally has a copper wire in the center (for the signal), some insulation around it, then a wire mesh (ground) and then the outer insulation. TV antenna cable is coax.This page has a picture.
Old Aug 11, 2003 | 07:12 PM
2001Millrunner's Avatar
sounds like you did it right =) just drive around the freeway to test your receptions with squelch off, ususally there are a lot of truckers around there....
Old Aug 11, 2003 | 08:35 PM
StoryR's Avatar
Again, pardon my ignorance on the matter...I meant antenna cable...Don't know what I am talking about...
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
