Question about 3VZE
Old Oct 12, 2003 | 09:26 AM
Juggalo's Avatar
Question about 3VZE
I just bought my truck about 1 month ago, and I'm just wondering why it's so loud when you first start it up, even when it's been off for 5 minutes and it's still hot, it makes a loud noise for about 20 seconds, than it goes away and it sounds smooth and quiet again.
I'm sure this is normal and you guys know what this is, can someone please explain what exactly makes this noise, and why?
Thanks
Juggalo
Old Oct 12, 2003 | 10:56 AM
95_4X4Runner's Avatar
It's caused by the fan clutch, and it's totally normal.
Old Oct 12, 2003 | 11:05 AM
JSharp's Avatar
If you close your eyes, you can almost imagine what it's like to be in one of those military hovercraft as the skirts inflate...
Old Oct 12, 2003 | 11:35 AM
Jonathan's Avatar
Oh yes the dreaded "my engine is about to take off" noise. My 92 PU did the same thing. Everyone asked me if my truck was about to blow up.
Old Oct 12, 2003 | 11:51 AM
Juggalo's Avatar
Thanks a lot guys, I knew it was normal, I just didn't know what caused it to do that.
But why does it only do it when you first start the truck up?
Juggalo
Old Oct 12, 2003 | 11:53 AM
OneTrickToy's Avatar
whoa... you guys are weird... my truck sounds fine at startup. I usually have to turn the air off to tell if my truck actually started or not. But on that note.....the engine was replaced around 100,000 miles by my anal retentive uncle. So it might just be that my engine is newer?
Old Oct 12, 2003 | 02:03 PM
Robinhood150's Avatar
Um, what does the noise sound like? Is it a ticking sound, screeching sound, wind sound, etc?
My 3.0 isn't loud for the first 20 seconds.
Old Oct 12, 2003 | 02:24 PM
ByThaBay's Avatar
I know the exact noise you are talking about, my truck has done it ever since it was purchased back in '93.
Personally, i really like the sound; i think it's cool and adds a really great sound to the vehicle upon startup.. sounds a lot meaner
i am not sure why it does this, but here is my theory:
when you are running your pickup, the engine is being cooled by the coolant/fan ... when you turn off the truck and then turn it back on after a few mins, you'll see that the temperatue guage will be slightly higher, this is becuase the coolant is not moving around and not being cooled off. Also, the engine is not being cooled at all, so all that heat is being dissipated by the block. I believe, that as a default, the engine is immediatey super cooled off on every start to prevent overheating.. but this is just my thoery, i don't know if it's the right reason for the sound or if there is even such a thing..
Old Oct 12, 2003 | 04:34 PM
Babypig's Avatar
As I live across the inlet from the coast guard that has a large hovercraft, I would have to say that you've hit the nail on the head.
Old Oct 13, 2003 | 07:29 AM
mtnfreak's Avatar
Well, I hope it's fan noise and not something that's knocking or grinding until it gets oiled up.
Old Oct 13, 2003 | 07:56 AM
Highland Runner's Avatar
Having my fan clutch apart many times to fix my overheating problem, I'll tell you why. When the engine is off, silicone fluid in the fan clutch floods the clutch plates (looks like a round maze). When the engine starts, the fluid is forced centrifically to the outside edges of the clutch where it is forced through 2 pin holes into the back of the clutch. During the time it takes the fluid to empty the clutch plates, the fan is fully engaged and spins at the same speed as the engine. That 's why its so loud, and it last usually 1 min or so. As the engine heats up (radiator gets hotter), the spiral spring on the front of the clutch turns a "valve" which lets this fluid back into the clutch plates, and the fan speed increases to cool the radiator. So most of the time drivng, air flow is enough to cool the radiator and the fan slips and doesn't make any noise. In stop and go traffic or hill climbs, you may hear the fan get loud again.
Flossy
Aug 5, 2015 05:14 PM
clok
Aug 1, 2015 09:42 PM
91yotapup
Jul 27, 2015 07:19 AM
88yodabasket
Jul 13, 2015 01:32 PM
