Pulstar spark plugs
Old Jun 20, 2008 | 05:59 PM
ajw62428's Avatar
Pulstar spark plugs
Just installed these plugs today. Hoping it will at least increase the fuel mileage. Has anyone else used them? I do feel alittle extra getup but never know for sure. Ill give an update if I see anything new with the GPM.
1997 4runner 2wd
SR5 3.4l V-6
K&N filter
Airbox mod
Old Jun 21, 2008 | 04:31 AM
Bighead's Avatar
Do a search on IH8Mud.com. There is a guy there that put those in his 80- or 100-series recently.
Old Jun 24, 2008 | 08:43 PM
icerunner's Avatar
Hi, A word to the Wise...
1997 4runner 2wd
SR5 3.4l V-6
K&N filter
Airbox mod
DO not use these plugs!!...
They are a marketing gimmick (in my opinion). Your spark is mostly predetermined and these plugs are not really a help...If you dont believe me do a google search for people who have used these plugs and almost ruinied their engines IE... the spark plug electrode falling off in the cylinder scratching the crap out of the cylinder walls...Fyi a little piece of metal like that can 100% Ruin your 7000.00 engine (dealer cost). I have heard of numerious reports of knocking and pinging being caused by these plugs shortly after install with poorly running engines. Reciently read a review from a guy who just bought a 5.7 tundra and his engine started to Knock and Ping whle going up a steep hill (after installing these plugs). After a nightmare of driving the truck for a week or two, he pulled the plugs and guess what he found....? The end of the plug was gone.....gee wiz its great to have loose metal in your engine causing all kinds of havok...
in my opinion, these plugs are 100% UN-PROVEN I believe it is all marketing BS... Don't take this the wrong way, yet If that was my truck I would have pulled those plugs out YESTERDAY... no joke.
Dont try to over/out think the toyota engineers on this one... trust me!
Old Jun 24, 2008 | 09:00 PM
corax's Avatar
NGK or NipponDenso only - NO BOSCH for sure - if you want to go fancy, try the NGK or ND platinum or iridium
Remember Split Fire spark plugs? I hate to say it man, but it really is just marketing
Old Jun 24, 2008 | 09:04 PM
86tuning's Avatar
I prefer Denso plugs for Toyota vehicles. They're only around $3/ea from the dealer. The correct plug for your engine is the K16TR11 which is a dual-ground-electrode plug, which will work fine for at least 24,000 miles.
Old Jun 25, 2008 | 04:07 AM
mkgarrison5's Avatar
mine lasted 70k miles :-) yes i changed them.
btw original poster.. not to flame you too much but take that POS plugs out and get denso or ngk. dont fall for stupid sheet you hear or see on tv. remember, those guys are trying to SELL you stuff so of course it will be hyped up
Old Jun 25, 2008 | 04:18 AM
BigBallsMcFalls's Avatar
what he said.
a spark is a spark is a spark. a hotter spark doesn't increase mileage one tiny bit. if the cylinder it lit, it is working. if it doesn't light the computer will figure that out and trigger a misfire MIL.
100% bogus to pay for some fancy plug that claims this and that, when in fact the engine ECU is running the show and is already optimizing the engine as much as it can be optimized without installing a whole new engine chip and fuel rail, injectors and whatnot.
save yer loot
this is an accurate post from a corvette forum on these things
A spark in the combustion chamber has one job and one job only...ignite the mixture. Once ignition has been obtained, the flame front progresses across the combustion chamber regardless of the manner in which ignition occurred. The average power delivered by the spark of each spark plug is about the same and the energy delivered is about the same too...based on their numbers, about .0015 watt-seconds for conventional plugs vs .002 watt-seconds for this scam plug.
I can make a case for the Pulstar plug making less power. They say their spark lasts 2 billionths of a second while in conventional plugs the spark lasts 30 milllionths of a second. That means there is a shorter amount of time the A/F mixture is exposed to a means of igniting, so if the swirling mixture isn't exactly the right ratio at the point of the Pulstar when it gets its' short burst, a misfire will result causing a reduction in power and with the new OBD II system, it'll throw an "engine misfire" code. The longer duration of the conventional plug means a longer opportunity to ignite a marginal mixture. This is like an engine that makes high peak power but only in a very narrow, very high RPM range vs an engine that has less peak power but it's average power over the RPM band used during acceleration (usuable power band) is much greater. The engine with less peak power will kick the high peak power engine's butt all the way down the quarter mile.
Just another company preying on the ignorance of the general public in these times of high gas prices. Put it in the same category as the "Tornado" device et al that claim gains in HP and MPG with a simple device that's cheap enough for people to say "what the hell, it's not much money if it doesn't work", but they make a killing because it cost them pennies on the dollar to produce. Whenever you see one of these simple "devices", ask yourself in these times of high gas prices, EPA demands for higher MPG, and the consumers clamouring for high MPG cars, why don't we see any single car manufacturer putting these gas saving/power making devices on their cars from the facory so they can be the first with a car getting 100 MPG???
I tell them about the great MPG of the 'Vettes and they slap their head and say "I could've had a V8!"
Old Jun 25, 2008 | 05:58 AM
pauliep13's Avatar
I have to agree... Denso or NGK only. I've tried the gimmick plugs before with no better results. So far the only "fancy" plugs I've tried that are half way worth a flip are the NGK iridium.
And X2 on the Bosch... leave those at the store.
Old Jul 3, 2008 | 10:09 PM
ajw62428's Avatar
So far disappointed with the decline in MPG even after I re-gapped the plugs so im changing the plugs out tomorrow. Save your money
Old Jul 7, 2008 | 06:53 AM
icerunner's Avatar
Good move!!
Save your money is right....
Good move brotha!!!
Old Aug 21, 2008 | 09:48 AM
Ron Helmuth's Avatar
thanks for the update and honesty.
Good to know what does and does not work.
Yep I do remember the Split Fire spark plugs.
Old Apr 13, 2010 | 07:39 PM
ajw62428's Avatar
Just an update I kinda got lazy and never removed the plugs but my MPG went back to normal but no real increase in MPG.
IAW http://www.fueleconomy.gov/ My online records only go back till after the swap to the Pulstar plugs but I was tracking on sheet records back then. Probably next month I will swap them out with regular stock plugs to see a real difference. I did get an small increase in static noise feedback from my speakers.
{PL=plus gasoline, $0.00=gas prices, lucoil=lucas oil injector cleaner}
DATE--MILES--REFILL (GAL)--TOTAL COST($)--%STREET/HIGHWAY--GPMS
10/11/2008 168952.0 14.528G $46.48 20% 80% 0.0
10/15/2008 169269.0 14.398G $45.48 20% 80% 22.0GPM
10/21/2008 169571.0 14.333 42.70 20% 80% 21.1
10/26/2008 169859.0 14.847 43.34 30% 70% 19.4
10/31/2008 170190.0 15.357 40.53 20% 80% 21.6
11/05/2008 170496.0 14.773 38.40 20% 80% 20.7
11/10/2008 170794.0 13.885 31.92 20% 80% 21.5
11/14/2008 171098.0 14.279 32.26 20% 80% 21.3
$2.25
11/19/2008 171428.0 15.587 33.34 20% 80% 21.2
$2.13
11/23/2008 171723.0 14.329 30.08 20% 80% 20.6
$2.09
12/01/2008 172031.0 15.812 29.71 40% 60% 19.5
$1.87
12/06/2008 172343.0 14.788 26.31 20% 80% 21.1
$1.77
12/11/2008 172655.0 14.966 26.92 20% 80% 20.8
$1.79
12/18/2008 172957.0 14.684 24.95 20% 80% 20.6
$1.69
12/22/2008 173260.0 14.717 25.00 20% 80% 20.6
$1.69
12/26/2008 173438.0 10.286 19.12 20% 80% 17.3
12/31/2008 173742.0 14.927 26.26 20% 80% 20.4
$1.75
01/08/2009 174052.0 15.219 27.07 20% 80% 20.4
$1.77
01/12/2009 174357.0 15.047 28.57 20% 80% 20.3
$1.89
01/21/2009 174658.0 15.474 30.31 20% 80% 19.5
$1.95
01/25/2009 174966.0 15.216 29.66 20% 80% 20.2
$1.94
01/30/2009 175253.0 15.138 31.17 30% 70% 19.0
$2.05
02/03/2009 175554.0 15.137 30.86 30% 70% 19.9
$2.03
02/07/2009 175832.0 14.904 38.58 40% 60% 18.7
$2.11
02/11/2009 176103.0 14.682 31.11 40% 60% 18.5
$2.11
02/17/2009 176399.0 15.141 32.69 40% 60% 19.5
$2.15
02/20/2009 176693.0 15.006 32.85 40% 60% 19.6
$2.18
02/24/2009 177017.0 15.577 33.32 40% 60% 20.8
$2.13
02/27/2009 177318.0 15.199 33.57 40% 60% 19.8
$2.20
03/04/2009 177615.0 14.944 31.67 40% 60% 19.9
$2.11
03/08/2009 177909.0 15.142 32.09 40% 60% 19.4
$2.11
03/12/2009 178202.0 15.499 32.22 40% 60% 18.9
$2.07
03/17/2009 178502.0 14.881 31.98 40% 60% 20.2
$2.14
03/23/2009 178817.0 15.838 33.56 40% 60% 19.9
$2.11
03/27/2009 179156.0 17.131 34.24 40% 60% 19.8
$1.99
04/03/2009 179458.0 15.475 33.10 40% 60% 19.5
$2.13
04/10/2009 179766.0 15.595 33.36 50% 50% 19.7
$2.13
04/14/2009 180077.0 14.051 30.44 30% 70% 22.1
$2.03
04/19/2009 180418.0 16.968 35.11 30% 70% 20.1
$2.06
04/23/2009 180758.0 16.369 33.70 30% 70% 20.8
$2.05
04/29/2009 181077.0 15.338 32.65 30% 70% 20.8
$2.12
05/03/2009 181403.0 15.168 31.53 30% 70% 21.5
$2.07
05/08/2009 181703.0 14.939 35.05 30% 70% 20.1
lost rec
05/13/2009 182037.0 15.939 35.05 30% 70% 21.0
$2.19
05/18/2009 182348.0 14.590 33.25 30% 70% 21.3
$2.27
05/22/2009 182666.0 15.391 36.92 30% 70% 20.7
$2.39
05/28/2009 182973.0 14.294 36.58 30% 70% 21.5
$2.55
06/02/2009 183278.0 15.557 38.41 30% 70% 19.6
$2.46
06/09/2009 183609.0 15.944 42.40 30% 70% 20.8
$2.65
06/12/2009 183907.0 14.647 38.95 30% 70% 20.3
$2.65
06/26/2009 184249.0 15.690 42.66 30% 70% 21.8
$2.71
07/02/2009 184570.0 14.950 38.86 30% 70% 21.5
$2.59
07/12/2009 184887.0 15.401 38.49 30% 70% 20.6
$2.49
07/16/2009 185194.0 14.429 35.77 30% 70% 21.3
$2.47 Lucus oil started
07/22/2009 185505.0 14.869 37.01 30% 70% 20.9
$2.48
07/29/2009 185820.0 14.500 36.24 30% 70% 21.7
$2.49
08/07/2009 186151.0 15.260 40.27 30% 70% 21.7
$2.63 Plus gas
08/11/2009 186490.0 15.166 41.39 30% 70% 22.4
$2.72 Plus gas
08/15/2009 186696.0 9.442 26.99 30% 70% 21.8
$2.85 Plus
08/21/2009 187022.0 14.666 40.46 30% 70% 22.2
$2.75 Plus
08/28/2009 187342.0 13.990 37.76 30% 70% 22.9
$2.69 Plus/Lucoil
09/04/2009 187695.0 15.874 46.97 30% 70% 22.2
$2.95/pl/luc
09/10/2009 188039.0 15.614 44.02 20% 80% 22.0
$2.81/pl/luc
09/17/2009 188374.0 15.242 42.97 20% 80% 22.0
$2.81/pl/luc
09/23/2009 188725.0 15.855 44.38 20% 80% 22.1
$2.79/pl/luc/air tires
09/28/2009 189069.0 15.793 43.26 20% 80% 21.8
$2.73/pl/lucoil
10/03/2009 189403.0 15.632 42.82 20% 80% 21.4
$2.73/pl/lucoil
10/09/2009 189767.0 16.680 45.02 20% 80% 21.8
$2.69/pl/lucoil
10/15/2009 190091.0 16.434 44.36 50% 50% 19.7
$2.69/pl/lucoil
10/23/2009 190435.0 16.482 44.48 20% 80% 20.9
$2.69/pl/lucoil
10/31/2009 190746.0 15.698 43.94 30% 70% 19.8
$2.79/pl/lucoil
11/05/2009 191059.0 14.958 40.97 20% 80% 20.9
$2.73/pl/lucoil
11/11/2009 191386.0 15.092 38.77 20% 80% 21.7
$2.56/pl/lucoil
11/16/2009 191746.0 17.361 48.94 30% 70% 20.7
$2.81/pl
11/23/2009 192050.0 15.270 43.05 30% 70% 19.9
$2.81/pl/lucoil
12/07/2009 192366.0 16.268 45.21 30% 70% 19.4
$2.77/plus
12/15/2009 192659.0 14.734 41.54 30% 70% 19.9
$2.81/plus
12/21/2009 192967.0 15.129 42.04 30% 70% 20.4
$2.77/pl/lucoil
01/08/2010 193289.0 16.053 44.61 30% 70% 20.1
$2.77/pl
01/12/2010 193604.0 16.107 47.34 30% 70% 19.6
$2.93/pl
01/17/2010 193908.0 14.548 41.74 30% 70% 20.9
$2.86/pl/lucoil/airtires
01/22/2010 194222.0 15.177 43.54 20% 80% 20.7
$2.86/pl/lucoil
01/27/2010 194520.0 14.850 42.60 20% 80% 20.1
$2.86/pl/lucoil
02/01/2010 194850.0 15.657 46.02 20% 80% 21.1
$2.93/pl/lucoil
02/06/2010 195183.0 16.043 45.55 20% 80% 20.8
$2.83/pl/lucoil
02/19/2010 195512.0 15.676 15.68 20% 80% 21.0
$2.91/pl/lucoil
02/19/2010 195874.0 16.666 46.98 20% 80% 21.7
$2.81/pl/lucoil/record 361.8m
02/26/2010 196185.0 15.273 43.67 20% 80% 20.4
$2.85/pl/lucoil
03/03/2010 196522.0 16.190 45.32 20% 80% 20.8
$2.79/pl
03/13/2010 196839.0 15.650 45.68 20% 80% 20.3
$2.91/pl/lucoil
03/18/2010 197179.0 16.246 46.45 10% 90% 20.9
$2.85/pl
03/23/2010 197496.0 15.169 43.37 10% 90% 20.9
$2.85/pl/lucoil
03/27/2010 197786.0 14.037 42.10 10% 90% 20.7
$2.99/pl
04/01/2010 198104.0 15.790 45.46 10% 90% 20.1
$2.87/pl
04/05/2010 198405.0 15.573 46.70 30% 70% 19.3
$2.99/pl
04/09/2010 198724.0 14.565 42.66 10% 90% 21.9
$2.92/pl/lucoil*?
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
raptor510
Aug 19, 2015 02:15 PM
accuracy
Aug 4, 2015 08:05 PM
defrag4
Jul 31, 2015 10:50 AM
