Power antenna won't go down
Old Mar 4, 2003 | 08:40 AM
Highland Runner's Avatar
I have a 98 Limited and the antenna stopped going down yesterday. It went about 1/4 down then stuck. The antenna motor still runs for about 10 seconds when the truck is started or shut off. I can't push the antenna down, but it will move up and down between 3/4 to fully extended. Is this a fixable problem? I think the motor has become disconnnected from the spool of plastic line. Does anyone have a scan of an exploded view of the power antenna? Thanks, Chris
Old Mar 4, 2003 | 08:46 AM
Bob_98SR5's Avatar
Chris,
The mast itself has plastic teeth at the bottom of it which spools itself to the antenna motor. Replace the mast and feed it w/ the teeth towards the back of the 4runner.
Or take a look at my write up on replacing the motorized antenna unit w/ a fixed "Taco whip" unit. I can't tell you how pleased I am w/ this mod. The only downside is that if you take your 4runner to a car wash, you better remove (or have it removed) b/f you go through the car wash---but then again, why are you taking your baby through a car wash anyways?!?!?
http://www.4runners.org/articles/whip
Bob
Old Mar 4, 2003 | 09:10 AM
midiwall's Avatar
Hi Chris;
I second Bob's suggestion about a Taco whip - or anything other than a power antenna.
I just replaced my power antenna with a $9 "rubber duckie" that I bought at Schuck's. It works great. I don't have issues with the antenna possibly getting bent from a low tree; I don't have the issue of one-more-mechanical-thing-to-go-wrong; and the reception is actually _better_.
Old Mar 4, 2003 | 10:06 AM
keisur's Avatar
Re: Power antenna won't go down
Yes, I did this exact thing with my '98.
Part Number: 86337-35111
Toyota Stealership price: ~$44.81
www.1sttoyotaparts.com price: ~$32.33
1st Toyota Parts
okamikai
Apr 30, 2018 10:19 PM
DeathCougar
Apr 1, 2018 11:29 PM
delmert
Sep 30, 2015 04:34 PM
TDonkey
Jul 26, 2015 10:14 AM
94yotaky
Jul 23, 2015 07:50 AM
