Power Antenna
Old Sep 22, 2003 | 07:59 AM
Unhappy Power Antenna
My power antenna is just died on me this weekend. I just replace the stock battery this weekend with Optima Red top and next day, my power antenna did not go down. When I played CD player then the antenna should go down but all I heard was the antenna motor running but it does not go down. Just wonderring anyone has this antenna issue or any ideas how to fix or replace. Thanks in advance.
Old Sep 22, 2003 | 08:08 AM
Larunner's Avatar
I replaced mine a month or so ago. The parts were like $30 not bad at all. The problem with mine was the teeth that pull the antenna back down broke. Its easy to buy the parts and install. Just pull the old one out and feed the new one down.
Old Sep 22, 2003 | 08:16 AM
Rayday81's Avatar
I think there is a write up of this done in the tech section. Check it out, I'm sure someone has done a write up of this very common problem.
Old Sep 22, 2003 | 08:18 AM
keisur's Avatar
You may also have to pull the motor assembly from the wheelwell and crack it open to remove the bits that broke inside the reel. When I did mine, I found about 15 teeth and the bottom half of the zip-cord broken off inside the reel. If you don't remove them you risk the new zip-cord jamming up and either getting stuck or breaking, or the antenna not going up or down correctly. it's easy to pull and open it up, just be careful once you open it not to lose the nut and screw for the housing and don't cut the plastic shroud off, just fold it up to access everything.
EDIT: Here is the part number you will need:
86337-35111
J.
Old Sep 22, 2003 | 10:19 AM
Jboy's Avatar
Mine broke right after my warranty expired. I`m was tired of that grinding motor sound so I disconnected it. I`m going to go with a regular antenna, someday.
Old Sep 22, 2003 | 06:20 PM
keisur's Avatar
Alot of guys go with the Taco whip type antenna. it is suppose to be less susceptable to breakage while wheeling. not sure but I usually don't have the stereo on while bumping around, I usually have the Sirius Satellite on Hard Attack or Octane so my antenna is retracted so mine seems to be protected.
Old Sep 22, 2003 | 06:26 PM
Fink's Avatar
I would get the Taco Whip setup...it looks much better and is MUCH more practical for us wheelers....there is a write-up in the tech sections that Bob did...a very good one at that
Fink
Old Sep 23, 2003 | 11:56 AM
Thanks for all the helps. I do have some tech write up to read.
Old Sep 23, 2003 | 01:36 PM
DSP's Avatar
DSP
I am also going with the whip ant.
But, I haven't ordered it yet and I cut my power ant off already.
Is there a way to disconnect power to just the ant. motor without cutting power to other accesories.
I want to know only so i too don't have to hear the whine of the motor doing nothing everytime i shut down power and restart.
thanks
Old Sep 23, 2003 | 05:59 PM
Victor's Avatar
Paid $18 for mine from a guy on ebay and it works great.
Old Sep 23, 2003 | 06:42 PM
CTB's Avatar
CTB
thanks
Ya, get to the antenna motor through the innder fenderwell, and then disconnect the power cord to it.
Old Sep 24, 2003 | 05:54 AM
Bob_98SR5's Avatar
Go with a whip (fixed) antenna. You won't be disappointed nor will you ever have to worry of it breaking. http://www.4runners.org/articles/whip
Bob
Old Sep 24, 2003 | 10:06 AM
rah1420's Avatar
There's an ebay merchant who sells a replacement power antenna. Look under "Other Parts" and look for the search term "Toyota."
I bought one from them for $18. It came via usps priority mail with instructions. If you really want to have the power antenna, this is a good option. These people are good.
My 4runner's still in the shop getting the sunroof done, so I haven't had a chance to replace it, but the instructions are pretty simple.
DeathCougar
Apr 1, 2018 11:29 PM
mussy01
Dec 13, 2016 08:20 PM
delmert
Sep 30, 2015 04:34 PM
Sidherish
Aug 2, 2015 01:42 PM
TDonkey
Jul 26, 2015 10:14 AM
