Plugs
Old Nov 20, 2003 | 08:52 AM
Churnd's Avatar
Plugs
Theoretically speaking, what kind of spark plug would work best with a higher output ignition? In other words, where the fire to the plug is alot hotter or more present than a regular plug. I just figured I'd ask since a few of you know quite a bit about internal combustion with the whole 2 steps colder plug with the supercharger thing.
I'm asking because I run a Jacob's Ignition and time's coming to replace the plugs in it now. Just wondering if I should consider something other than the standard resistor type plug.
Old Nov 20, 2003 | 11:36 PM
sick4runner's Avatar
from what i can put together, (and i am far from sure bout this one) maybe a slightly higher quality metal like the new NGK iridium and opening the gap a touch is just enough to get the peak output from an upgraded ignition! if anybody knows better i would like to know as well but i amfarely sure this is correct.:beaver:
Old Nov 21, 2003 | 07:42 AM
Churnd's Avatar
I'm pretty sure I'm running platinum plugs in mine right now and I did notice a better response than with the stock resistor type plugs. I might try out the NGK's and see what happens.
80Truck
Oct 12, 2025 07:25 PM
Blamalam
Mar 12, 2022 07:34 AM
old87yota
Oct 25, 2015 02:15 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
msane99
Jul 17, 2015 10:13 AM
