Pinging when engine warm
Old Aug 8, 2005 | 11:24 AM
GaryBee's Avatar
My 92 4-runner v6 3.0 runs smooth at start up but it reaches normal running temp there is a pinging noise at 3000 rpm or greater. Changing fuel doesn't seem to change it. Does anyone have any ideas what might be causing the problem?
Old Aug 8, 2005 | 11:36 AM
rimpainter.com's Avatar
When you say "3000 RPM or greater" you did not mention if that was under load (driving) or at idle. Which is it?
Old Aug 8, 2005 | 11:58 AM
GaryBee's Avatar
The pinging can be heard even when stopped and just revving .... It also occurs during driving but doesn't seem to matter if climbing a hill or on a flat section
Old Aug 8, 2005 | 12:02 PM
I would look for something loose on the rotating assembly then. The idler pulley is of particular interest here. Shut the motor down and check for play in everything you can, such as the PS pump pulley, AC compressor pulley, etc.
This doesn't sound like detonation to me since it is happening while sitting there and revving it too (rarely does that happen unless your timing is completely whacked out).
Old Aug 8, 2005 | 12:06 PM
Unhappy99's Avatar
Check fuel injection pressure at the rail. If its low, you are running lean, which will ping. Then the question is, 'why is the pressure low'? Not many things to go wrong here: Fuel pump, regulator, filter.
Old Aug 8, 2005 | 03:29 PM
Ironmike4x4's Avatar
I'm very impressed unhappy.... diagnostic skills at its finest. Ever thought about working as a mechanic?
Old Aug 9, 2005 | 05:44 AM
Unhappy99's Avatar
I take shadetree mechanicing one step farther and work entirely in the dark.
Sleaker
Aug 26, 2020 06:03 AM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Jonny246
Jul 12, 2015 04:51 AM
Kluch8651
Jul 9, 2015 10:39 AM
