Performance Radiator Question?
Old Nov 13, 2017 | 11:18 AM
the1998-sr5's Avatar
I have a 1998 t4r 3.4 4wd.
It runs hot in certain situations.
Long hills, towing a small trailer and offroad.
Whenever I put the heat on she cools right down.
I want to put a high performance radiator in it, does anyone have recommendations of one that will fit, I see cheap 2 and 3 core options on ebay- but I don't know whats good for my vehicle.
Now before we get into the weeds here, I know my engine should not run hot- and it would be better to fix the underlying cause.
I'm ready to give up on that- it's been doing this for 5 years and I've had countless mechanics look at it to no avail as well as replacing everything in the system and trying to track different parts of the engine with a temp gun.
At this point its cheaper to just get a stronger radiator, whenever I put the heat on she cools right down- so I think I just need a bit more cooling capacity.
Any advice on radiator option other than my Koyo would be helpful.
Old Nov 13, 2017 | 12:06 PM
wyoming9's Avatar
Red face
Not sure what your problem might be.Do you have a Automatic??
I run the same Radiator in both my Tacoma and 4Runner both 3.4 5 speeds
Copper /Brass 3 row that I bought from the long gone Radiator Barn
It is not uncommon to have a 1000 pounds in the bed Towing another 2500 or so with no cooling problems
If I am Hot the AC is also on
Then it is not in the Hot temperatures of the Southwest USA!!
Old Nov 13, 2017 | 12:10 PM
Wyoming- thanks for the quick reply. You actually tried to help me track this down a few years back.
Do you think this would be a good option:
https://www.radiatorexpress.com/prod...SABEgJn8_D_BwE
I just found this one today. Is there a cooling metric I should keep in mind like the way BTUs describe air conditioning?
Old Nov 13, 2017 | 11:51 PM
wyoming9's Avatar
Red face
With cooling systems it is system capacity
The size of the radiator core you can have a huge core but if it is not getting proper air flow either blocked in front or bad fan clutch .
Then the correct thermostat and working correctly
I recall reading about a High output fan as part of a Factory or Dealer added Tow package .
Weather a bigger Radiator will fix your issue is at best a guess
