Performance Brake Pads Good/Bad?
Has anyone bought and tried these for our 4Runners? How do they compare over stock...dust etc... I need new pads and want to see if these are really and upgrade or not?
There are a very limited number of brake friction material manufacturers in the world. I repair brakes daily and have found (barring specialty products) that the GCD pads sold by carquest which are made with ceramic, or the Kevlar pads sold by NAPA are among the best I have seen for eliminating brake dust problems.
I have had far better luck with Carquest friction materials as a commercial installer, and therefore recommend them. I have not, as of the time of this writing checked to see if they are available for 4-Runner application as they are continually widening the line of application availability.
I have not yet seen the brakes which you mentioned and therefore can not answer that question.
Dave & Cindy,
I appreciate the advice, but really all I am looking for is improved stopping power from new brake pad upgrades. I don't know if by replacing the brake pads only I can improve my stopping power? I want to keep everything else stock, but the new pads might help?
I haven't heard of those. On my Paseo, I've used TRD's carbon metallic pads and Performance Friction's CM pads. I liked them both, but TRD's pads "felt" a little better (even though they're supposed to be the same). I experience no fade and excellent modulation/road feel with CM pads. When it's time for a brake job in my 97 Runner, I'm going for CM pads.
Chris
Chris
For resistance to fading the Ceramic and Kevlar are a definite improvement. They are "Racing" brakes for their resistance to fade.
Theoretically organic (non-metalic pads) are supposed to provide more "grab" as they are a softer material, and like tires, the softer the material, the better the traction. I cannot vouch for this train of thought though as I have not done a comparison on like vehicles.
hope this helps.
hope this helps.
hope this helps.
hope this helps.
Chris
I would highly recomend cm pads and slotted rotors, I installed them on my volvo, and they worked perfectly. I travel a very twisty mtn. road every day to work. I tarnished/warped two sets of the stock brembos that are the original volvo parts. I had my car fixed at a performance shop, and they recomended the slotted rotors, and I of course jumped on the idea! I had them on for a year, and had no problems with them at all! It is true that the cm pads take a little to get them warmed up when they are really cold, but because there are drums in the back of the Runners, even if they were completely cool and you had to make an emergency stop you would be fine. You will also notice the pedal to be harder. They will require a little more foot oomph to get them going, but well worth the extra effort! I have already warped the stock rotors on my runner and will be getting the slotted cm upgrade soon, but i'm going to college soon and I won't be taking my car, so it might have to wait til next summer :cry: but there is a chance I will have it second semester. I'll keep you posted if I get it done, but in the mean time, you will love the upgrade!
http://www.rodmillenstore.com/tacoma/price.htm
or Performance Products has them both, as you said...
Co-Founder/Administrator
Sometime before Xmas I got brand new rotors from Toyota as my old ones were warped.
I had them put in new Toyota pads too.
Everything works good except when I first take off in the morning and apply them, they squeel like crazy which is annoying.
It only does it the first few times you hit the brakes to slow down.
I'm wondering if the dealer did not apply antisieze to the pads or something.
I may switch out the pads with some help myself one day for another pad.
Are these Perf CM pads a good drop in choice for stock rotors?
This was on a paseo, I have no idea how it will work on a 4Runner.
Chris
I've had no complaints about warming up the Ceramic or Kevlar pads, but most of the rigs I end up putting them on usually don't take long to warm up the pads.
The squeal in the morning is often attributed to moisture, but unless you're getting dew in the mornings, or have had rain, you shouldn't have the sueal, I'd take it back to the installer and have them check the pad back lubrication. I've learned through experience, that anti-seize ain't the stuff to use on the pad packs, and that SylGlide is the best all aroud squeal stopper. I avoid the greases too because of the potential rubber damaged to the caliper boot if there is inadvertent contact.
I love being able to install slotted rotors aka severe duty rotors because once instaled, the heat cracking and warpage complaints disappear.
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
justdifferentials
Just Differentials
Aug 30, 2015 08:42 PM
harrisdawg
Jul 26, 2015 09:42 AM
