painting your intake manifold
Old Feb 25, 2004 | 04:55 PM
934rnr's Avatar
painting your intake manifold (plenum)
I was thinking while I have my intake off I could use my wire brush on it clean it up and paint it red like my heads.. I know no horsepower gains just bling but it would look cool. Would there any adverse problems by painting the intake manifold? IE: heat issues?
Old Feb 25, 2004 | 04:59 PM
oly884's Avatar
Guest
Are you talking about the intake manifold or the plenum? I'm imagining that you are talking about the plenum because the manifold is under the plenum and you can't even really see it. As for the heat issue, there shouldn't be any problems. Just make sure that you get high temp paint because that thing gets pretty hot.
Old Feb 25, 2004 | 05:10 PM
934rnr's Avatar
Sorry I mean the plenum yes not the intake manifold.
I have some red 500 deg engine paint I used for my heads so that should work ok on it.
Old Feb 25, 2004 | 05:11 PM
oly884's Avatar
Guest
Originally Posted by 934rnr
Sorry I mean the plenium yes not the intake manifold.
Yeah, that stuff should work just fine. Take some pics when you get it done.
Old Feb 25, 2004 | 05:14 PM
amusement's Avatar
Sounds great!
Don't forget to use wax and grease remover before painting.
Look foward to the pictures.
Old Feb 25, 2004 | 05:18 PM
934rnr's Avatar
This is how it did look.
I have my engine torn down to the heads right now I am redoing my intake and exhaust cam shims as well a putting in some helicoils for one of the camshaft caps.
Old Feb 25, 2004 | 05:54 PM
amusement's Avatar
ahhhh
What's the breathers placed on top of the timing cover for?
Old Feb 25, 2004 | 08:07 PM
934rnr's Avatar
One for the EGR and the other is for the valve cover.
I don't think it will get painted tonight I took it apart the damn inside of the plemium has tar like creocote crap all in it so I am taking down to have it hot tanked tomorrow.
Old Feb 26, 2004 | 03:52 PM
934rnr's Avatar
Ok here are some pics of it:
Before painting the top of it.
Pics without the flash
It came out pretty good as you can see the 3.0 V6 sticker fell off when it was hot tanked but I think it looks good without it.
I'll get some pics up when it's installed back on my runner.
I did about 2 coats of 500 deg universial red on it. I think for a cheap mod it looks pretty good.
Old Feb 26, 2004 | 04:28 PM
Vato Loco's Avatar
That looks real good! When are we going to see the engine pics?
Old Feb 26, 2004 | 04:34 PM
934rnr's Avatar
Thanks I am still ironing out the intake and exhaust valve adjustments so it should be by this weekend hopefully.
Old Feb 26, 2004 | 05:10 PM
lunatic14r's Avatar
looks really good man whats that worth about 15 or 20 hp should have chrome it it would go faster hahhaha
Old Feb 26, 2004 | 05:57 PM
934rnr's Avatar
I used my dremel and poslished it a little to make the toyota letters stand out for that olde school toyota engine look.
I can feel the extra HP now....
I know I'm a sick puppy but the damn thing was bothering me looking all sad and oxidized...
Old Feb 27, 2004 | 08:11 AM
934rnr's Avatar
Well all that work now I gotta pull the head I tried for a couple hours to get the #6 exhaust valve shimmed it turns out the valve is burnt so the head has to come off again.....
Old Feb 27, 2004 | 08:22 AM
Gadget's Avatar
First there is never any reason to use 500* paint on your engine. If those metal parts ever get 500* you will need a whole new engine.
Painting those kind of parts is usually not a real good idea. Someday the paint will start to peal off and then it will really look bad.
Here is one from a 3.4 that turned out really nice.
The best way to do these kind of parts is to powder coat them. In that process the parts are super cleaned and then bead blasted and cleaned again. Then the powder is applied with an electrical charge and then the part is baked at high temp to melt and bond the coating to the part. This results in one of the more durable finishes for this type of application.
Gadget
Old Feb 27, 2004 | 08:32 AM
934rnr's Avatar
That's a nice job but how many bucks did it cost to do that?
Old Feb 27, 2004 | 08:53 AM
MTL_4runner's Avatar
Powdercoating is not too expensive but it ain't cheap either.
I say if you like the orange and don't mind touching it up periodically, paint is fine.
It is a pretty intense color.
Old Feb 27, 2004 | 10:25 AM
Gadget's Avatar
That was part of a $LOTS turn key 500 RWHP intercooled centrifugal supercharger with blue printed engine build...
Gadget
Old Feb 27, 2004 | 11:59 AM
signu's Avatar
Exclamation
934rnr,
I have the same engine as you and was just about to adjust the valves because it is ticking loudly at 208k miles. How annoying of a job is this, timewise and everything. I've adjusted valve clearance on the 22r and an integra but those were both screw adjustable. How much more difficult is it with shims.
-Scott
Old Feb 27, 2004 | 12:17 PM
Waterboy's Avatar
-Scott
https://www.yotatech.com/forums/f2/3-0-valve-adj-how-much-did-you-pay-17740/
https://www.yotatech.com/forums/f2/ticking-valve-24674/
Corvoid
Jul 4, 2021 11:51 PM
Marsheen
Feb 17, 2016 12:29 PM
Corvoid
Sep 4, 2015 11:55 AM
ManzDaKlown24
Aug 22, 2015 10:25 PM
Dakotaneu
Aug 15, 2015 07:24 AM
