Paddle shift 4runner project
Old Dec 16, 2011 | 06:29 PM
  #141
irab88's Avatar
hahaha...
Old Dec 19, 2011 | 11:21 AM
  #142
Clownmeat's Avatar
Under construction. Some of the parts were wrong, so more waiting.
Old Dec 19, 2011 | 11:37 AM
  #143
irab88's Avatar
why are you using analog in, as opposed to digital in?
just curious is all
Old Dec 19, 2011 | 11:38 AM
  #144
xxxtreme22r's Avatar
Ok now my head officially hurts.
Old Dec 19, 2011 | 11:43 AM
  #145
irab88's Avatar
and i just noticed the led's ain't hooked to nuthin
Old Dec 19, 2011 | 12:20 PM
  #146
Clownmeat's Avatar
It's not done man, come on, just testing stuff. The LED's all have a different brightness, therefore some tweaking will be done to make them almost match, then put in a acrylic mount.
Old Dec 19, 2011 | 12:26 PM
  #147
irab88's Avatar
i guess that makes sense, never would have thought of that
  #148
wii_tarded's Avatar
I know it may be a little too late, but why use LED's? I think a 7 segment display would have worked nice, and taken up less room.
Old Dec 19, 2011 | 12:44 PM
  #149
Clownmeat's Avatar
The idea came up about using one, but just didn't get around to fiddling with it. But hey, I get to see four different pretty colors instead of just one color like alarm clock red all the time.
There is room for added featured/upgrades/improvements and you could incorporate all kinds of cool stuff, but still comes down to I just want it to shift gears to begin with.
Old Dec 19, 2011 | 12:55 PM
  #150
Texas_Ace's Avatar
Along these lines why not use one of those multi-colored LED's? They have LED's that can have 7 colors in 1. Would make the LED fitment/install easier.
Old Dec 19, 2011 | 01:30 PM
  #151
Clownmeat's Avatar
There is lots of ways to do it for sure. Guess I just like the idea of a small light bar across the top of the column that moves left and right and changes colors. That's one of the fun factors in this project is that it's custom made however I want it. Hell, maybe I will make it honk the horn every time I shift.
Old Dec 19, 2011 | 02:00 PM
  #152
BMcEL's Avatar
Do it!
Old Dec 19, 2011 | 02:06 PM
  #153
Texas_Ace's Avatar
And it is a perfectly fine way to do it. Just a bit harder.
In my MR2 I installed my knock sensor light bar across the top plastic trim piece above the cluster. The LED's stuck though it a little bit and are unnoticeable until they light up. Nice out of the way yet easy to install and see place. I love it personally. I wish I had got a video of it when it was working.
Old Dec 19, 2011 | 03:35 PM
  #154
Clownmeat's Avatar
Who doesn't like a challenge, the easy way out isn't any fun.
Old Dec 19, 2011 | 05:05 PM
  #155
Clownmeat's Avatar
Chip is programmed to test the logic, it works! Cycles through all 4 positions, if in 1st and down shift again does't go to 4th and if in 4th and up shift doesn't go to 1st, if both buttons are hit simultaneously it doesnt change positions, LED's progressively follow gear position, stuff like that.
Old Dec 19, 2011 | 05:44 PM
  #156
irab88's Avatar
how did you debounce the buttons?
Old Dec 20, 2011 | 06:43 AM
  #157
Clownmeat's Avatar
Debouncing the buttons in software. Inputs are watched to make sure it appears stable for 50 milliseconds before accepting it as "the truth."
Old Dec 20, 2011 | 06:47 AM
  #158
irab88's Avatar
cool, thanks
Old Dec 20, 2011 | 06:48 AM
  #159
wii_tarded's Avatar
I have been thinking of building up a lighting kit for the tach, that will progressively change from green to red the higher you rev the engine. You will need the controller for the RGB LED's and an analog input.
Old Dec 20, 2011 | 08:06 AM
  #160
Leviticus6432's Avatar
Wow, this is cool. I am actually doing nearly the same thing for my truck. I have a 88 pickup with a tbi 4.3 and a 4l60e in it. I have been using arduino to make paddle shifters for my pickup, lol. The gm 4l60es are actually controlled nearly the same way as the A340s. Just different solenoids at different times. Let me know if you need any help, I might just be able to answer some of your questions.
