Ordered New Runner
Old Dec 8, 2003 | 11:53 AM
bocephas70's Avatar
Ordered New Runner
I just put in an order for a Limited V8 4x4 in black (no XREAS). Dealership has not given me a date yet. Does anybody know when the Daystar lifts are coming out? Do I need the 1.5 or 2.5 inch kit to fit 32's (265 70's)?
Thanks,
Barry Dickson
Old Dec 8, 2003 | 12:22 PM
CTB's Avatar
CTB
I believe a 32" tire is equivalent to a 265/75R16 in metric.
I doubt you need a whole lot of lift to run a 32". I bet a 1.5" lift would allow you to run that tire. Check with fourrunnabilly and a few other who have done lifts on 4th Gen's (try a search).
Old Dec 9, 2003 | 05:15 AM
Dr. Zhivago's Avatar
Away
I'm pretty sure that the new 4 Runners (that's how the new logo looks, so I'm going to write it like that ) come with 265/70/17 tires, which are exactly the same height as 265/75/16's. So, you won't need ANY lift to run those tires...
Maybe you meant a different size?
G
Old Dec 9, 2003 | 06:24 AM
Lefty's Avatar
Bo,
Congrats on your purchase ! Got a couple answers for ya:
Daystar should already be out with their 4Runner lift. I had the prototype on my truck and got switched out for the production one back in September/October. It ends up being a 2.5" lift once you are done with it. Go to Daystar's web page and see if they have it advertised yet. Better yet, drop them a line and see where they are at.
Factory tires are 265/65R17s, which equate to a 31" tire. With my lift, I went with 265/70s (~32" tire) on a rim with less backspacing. IF you stick with a factory backspacing/rims, you probably could stuff 285s (33" tire) under there with little problem. Of course, things will be a bit tippy with that setup.
Good luck ! Hope you like your runner !
Steve
Old Dec 9, 2003 | 08:09 AM
CTB's Avatar
CTB
G
Oh ya, forgot about the 17" rims...
Old Dec 9, 2003 | 11:45 AM
bocephas70's Avatar
Steve,
The new lift is not on Daystar's website. I will email them and see what they say. I wanted to go with 265/70/17's (32's) BFG's on stock rims. I'll go with the 2.5 inch lift just to make sure I have enough clearance for off-road.
I got a few questions:
1. Does the lift raise the front and rear the same amount?
2. How bad is it on the drive train/joints?
3. Does your vehicle drive/ride any different?
4. Would you recommend new rims? If so, what kind?
Thanks for the help,
Bo
Old Dec 9, 2003 | 12:17 PM
GATORSR1's Avatar
Congrats!
Out of curiousity, why "no XREAS?"
Old Dec 9, 2003 | 12:27 PM
bamachem's Avatar
With XREAS, you can't EASILY upgrade the shocks for the lift.
Old Dec 9, 2003 | 04:24 PM
Lefty's Avatar
Bo,
Giving you the executive summary to your questions, you are good to go ! Here are the details:
1. Actually, no, the lift doesn't raise the front and back the same. The front is about 2.75", the rear is just shy of 2.5". This levels the truck quite nicely. I am actually still .25" low in the front.
2. No problem on the CVs nor ride quality. I couldn't tell the difference. Front driveshafts are straight across after the lift, so no CV boot problems as plagued the Tundras.
3. Yes and no. Yes, I had a ride difference after the lift with the stock tires/wheels. It was tippy, due to the raised center of gravity. After getting the new wheels/tires, however, the truck rode the same as stock. The tippiness is gone.
4. Do you need new wheels/tires ? No. Will it help cornering and handling ? You bet ! It made a huge difference once I got the new wheels. I highly recommend getting new wheels with less backspacing after getting this lift.
If you do a search on this forum for my name, you should be able to get a bunch of info on the lift and wheels/tires I have. In addition Fourunnabilly has also done some lifting to his Runner. Getting the info from both of us and making an educated decision, you really can't go wrong.
Good luck !
Steve
Jnkml
Jul 6, 2015 01:20 PM
Steezy96yota
Jul 6, 2015 10:00 AM
wilbertd
Jul 6, 2015 07:39 AM
coryc85
Jul 6, 2015 04:07 AM
HRDC0R19
Jul 5, 2015 06:43 PM
