Optima/H.O. Alt/Cap...Or is it just me?
Old Jan 28, 2004 | 01:17 PM
hey steel head you got it....you do need to run a thicker ground so make sure its thicker than any exsiting wires....so it would be best to run a 0 gauge wire if you can but 4 will work fine...that what i have on mu truck....and also on the toyota frames most of the holes are prethreaded so just run it to one of those..its prett simple and i noticed a huge differnece in my lights
And also if you guys didn;t already know this make sure you system us turned dowm real low when your turck is cold...like below freezing...expecially your subs...when they are cold everything is smaller...even though its only slight the voice coils and all theparts rub together more and the subs can be dammaged or may blow...so for the first 10 minutes or so when your system is on make sure your subs are turned down....just till they warm up...they warm quickly tho...
Cody
