ome/tundra final questions
Old Oct 6, 2006 | 07:09 AM
UNR.Grad's Avatar
Originally Posted by E-money
Once again Steve you make a lot of sense. However, on kit #7 can I get the 891's instead of the of the 890's?
I second what Steve said, I have the 891's and while they are nice the two times a year we use the runner to launch our 26' sailboat in/out of Tahoe for the season, daily driving leave much to be desired, they're very stiff.
Steve: Did you ever post something saying that you would be switching back to the Tacoma dual valved TRD struts from the trekmasters because the dual valved really makes a difference?
Old Oct 6, 2006 | 05:47 PM
914runner's Avatar
Originally Posted by sschaefer3
3.5" is fine. 4.5 and over is where it gets strange. My Dana 44 front is 4.5" of lift over stock and I have yet to see anyone build anything that low. If you made it any lower, you would have serious oil pan contact all of the time. Even with the 2WD T100 pan.
This is also why my shackles are in the front, the axle moves forward and just misses the oil pan. Now if you build a Monster Truck, none of this matters as it's so high everything clears.
Im not into monster trucks. I like my rigs with just enough lift to clear the size tires I want to run, flexed out and able to steer at any flexed position.
I plan on doing a 1UZFE swap so I would be treading new ground either way if I kept IFS or did the All Pro SAS.
Old Oct 6, 2006 | 06:40 PM
BeachRNR's Avatar
I recently searched all around for prices on each part for the tundra/ome lift. After adding it all up with shipping costs plus not having the panhard drop bar,diiff drop,rear brake line and parking brake bracket plus the support of Sonoran Steel I found that in the long run it was better and easier to go with Sonoran.
And believe me I have done my research as far as prices go. I have ocd.
Old Oct 8, 2006 | 10:22 AM
sschaefer3's Avatar
No absolutley not. The blue shocks have fallen from grace for me and the green Trek Masters is what I feel is the best shock for the kits.
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
Team420
Dec 30, 2015 01:31 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
thefishguy77
Jul 30, 2015 10:59 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
