Is this OME setup safe?
Old Apr 9, 2003 | 02:56 PM
White SR5's Avatar
I'm considering an OME lift, but I don't want problems! My setup is as follows: Front-- (2) OME881 HD coils,(2) N91S (standard) or N91SC (comfort) shocks, and (2) OME 1" Trimpackers; Rear-- (2) OME891 HD coils and definately (2) N86 (standard) shocks. Tell me if you think this would keep me safe: OME881 HD vs. OME 882 VHD front coils, 1" OME Trimpackrs (or any brand 1" spacers), the Revtek differential drop kit , and then tightening some heavy duty hose clamps around the CV boot. Would all 4 erase all doubt? What benefits would adding a pan hard drop do for my rear axle, or is it necessary? I have just over 200lbs. of stereo in the back of my 4Runner, so I won't get te full effet of the OME891's, but will the lift strain the rear axle? Also keep in mind that I'm not an extremist when it comes to off-roading. I'm set on the rear for coils -- definately OME891's.
Zach
Old Apr 9, 2003 | 03:25 PM
RTdawgs's Avatar
honestly, everyone's CVs act different to lifts.
most people however, are fine with the 881 (w/ trim packers) and 891 combo.
Old Apr 9, 2003 | 03:31 PM
INsr5runner's Avatar
I'm doing the OME Medium's all around, with HD shocks, and 1" spacers up front...
Can't wait to get my shocks in!!
There is a post by a guy here that had some FUNKY angles on cv's (he used HD'S) during a recent install. you should read that post!
Now that my lift is almost complete and ready to install, I'm thinking about just waiting and getting SAW's. I plan on a TJM this summer anyways. *sigh* no money for anything but the truck...oh well!
~Mike
back to doing homework damn you yotatech....
Old Apr 9, 2003 | 03:33 PM
RTdawgs's Avatar
he used 882s.
Old Apr 9, 2003 | 04:01 PM
ssbogger's Avatar
i used to have horrible angles on my old truck. I went to Advance Auto (I'm sure any auto parts store might work) and bought a new CV axle for $80. It comes with a lifetime warrenty and i would blow one out about every 2 months so i would just take one off, take it back, and they would give me a new one. You can do this if you dont want to have to worry about your angles. BTW this was for a 90 chevy truck. I dont know what the deal would be for a toyota.
Old Apr 9, 2003 | 04:03 PM
TDiddy's Avatar
Yep, that was me. 882's are a waste of time unless you're putting a heavy bumper and winch on there. ARB themselves would agree. The diff drop has a minimal effect on your CV's with those shocks.
True, everyone's rig will act differently. I expected mine to act differently than what I currently am experiencing. Good luck if you go with it, but you have been warned. I'll let Steve Schaefer pick up where I leave off.....
Old Apr 9, 2003 | 04:23 PM
cruizin01's Avatar
Just thought Id let you know that if you are gonna do this soon you'll have to go with the medium shocks up front becuase the SC's are on backorder...Found that out this week when I tryed to get some.
Old Apr 9, 2003 | 06:52 PM
White SR5's Avatar
Definate Setup
Yep I found that out today when I called Mike at Xtreme Offroad and Performance. We figured out a definate setup now. It's going to be OME881's, N91S's, and OME trimpackers in the front, and I'm going to do the $30 differential drop for some extra insurance. For the rear, I'm going with OME891's and N86's. Both sets of shocks are regular, but OME's are supposed to be rated extremely soft, so I'll be OK. Both sets of coils are HD (not VHD)The extra hose clamps cost next to nothing. I actually almost sort of stole two from Home Depot yesterday (they were on the ground out of the store, still wrapped though). Maybe $3 tops. I think I'll be OK, and I might add a brush guard later to increase the weight in front. No new bumpers or winches though. Should I get myself into a fix, I'll be sure to post another "3rd Gen CV's, Am I In Trouble?" . I have a buddy -- well actually a couple of buddies -- 3 bottle jacks, 1 hydraulic jack, WD-40, tools up the wazoo, and jacktands, but no kind of spring compressor. Does one only require the use of the spring compressor for replacing the front coils? Is it possible to substitute 1 or 2 bottle jacks for a spring compressor? And if so, is it probable? Thanks again Yotatechers for the info.!
Zach
Old Apr 9, 2003 | 07:22 PM
RTdawgs's Avatar
sounds good. did you order it yet?
Old Apr 9, 2003 | 07:32 PM
XtremeOff-Road's Avatar
I would not have...Xtreme Off-Road is a scam!! LOL naw he is going to check around..actually do the same thing I would do!!
Mike
Old Apr 9, 2003 | 07:42 PM
White SR5's Avatar
Talking Hehe
Hehe I'll be calling you before Sunday Mike! How was the ride home BTW? Nope haven't ordered them yet, but I see the light at the end of the tunnel.
Zach
Robinhood150's Avatar
Re: Definate Setup
Zach
Compressing springs can be extremely dangerous, even with a real spring compressor. It was even scary using a hydraulic compressor, you should have seen how much the compressor bent under load. Go down to autozone or something and rent one.
Always use the right tools for the job.
Old Apr 10, 2003 | 12:04 AM
TDiddy's Avatar
Re: Definate Setup
Sure, if you would like to take first place in the next round of the Darwin Awards!
Steve's right, you do need to be extra careful when using a spring compressor. The hydraulic one we used was much more beefy than the ones you rent, and the springs really torqued it.
Old Apr 10, 2003 | 01:17 AM
DuB's Avatar
DuB
It doesn't cost anything to rent spring compressors either. You just put down a $30 or so deposit, and you get it back when you return the compressor. I used one when I installed my spacers way back when.
Old Apr 10, 2003 | 07:10 AM
TDiddy's Avatar
Yeah, I think the Kragen Auto Parts stores out here charge $6, with a $50 deposit. If you do get charged, the cost is minimal.
Old Apr 10, 2003 | 09:07 AM
When I get around to this install, I will most likely rent one from Autozone... Are those really that reliable? People's views seem to lean toward the "the rental ones are sketchy" side.
kawazx636
Oct 6, 2021 03:03 PM
ZGjethro
Jun 7, 2017 11:04 PM
A2theK
Oct 14, 2015 07:10 AM
Truckwithoutaname
Oct 3, 2015 03:41 PM
4runnerFireman
Sep 29, 2015 06:24 AM
