OME lift or OEM lift?
Old Feb 18, 2007 | 12:04 PM
99SR5's Avatar
ok so i am contimplating on what lift i want... i just want to hear oppinions on these lifts. advantages, disadvantages to each and so on. yes i do know about the search but i keep getting mixed answers and it just doesnt help. ask any questions you might need.
Old Feb 18, 2007 | 12:06 PM
Elton's Avatar
are you looking for a 2'' a 3'' or bigger ?
Old Feb 18, 2007 | 12:07 PM
99SR5's Avatar
um 2.5-3" i want to be able to fit 33" and not rub, but im not gonna buy tires for a little while so i dont want it to look goofy.
Old Feb 18, 2007 | 12:08 PM
UNR.Grad's Avatar
Not too be rude, but this subject has been beaten to death you will just be getting the same contrasting opinions that you found when you searched.
With that being said, go OEM.
Old Feb 18, 2007 | 12:22 PM
99SR5's Avatar
lol yeah i know i kinda feel like an ass for asking this again... so you say OEM? any reason why OEM over OME?
Old Feb 18, 2007 | 12:32 PM
4unner4life's Avatar
I would go OEM all the way. I say OEM because it is proven the best on and offroad capability. I know if you do any towing that the OME rear springs are a little bit better due to the stiffness. As far as the front OME coils go, I have seen through many threads of how they sag dramatically over time. i have had my OEM lift on for about two months and it is awesome on and offroad. They only thing you should know about the OEM kit is that the rear LC coils are a little high at first, but they do settle, mine has settled about 1" in about two months. If you do go with the OEM lift, you should throw on a
1" body lift and your 33's will fit very well. I have 33x12.50s and they don't even rub at full stuff(mostly due to the correct backspaced rims).
Daniel
Old Feb 18, 2007 | 12:47 PM
MTL_4runner's Avatar
For 33's just go with the Tundra coils up front (with topout spacers) and OME 890's in the rear unless you're looking to do a significant amount of offroading and are willing to give up some gas mileage to run the rake the LC coils give you. If you need a bit more height just do a 1" body lift to give yourself more room.
Old Feb 18, 2007 | 12:50 PM
FUZION's Avatar
well put...
Old Feb 18, 2007 | 01:12 PM
99SR5's Avatar
the thing is i dont know if i want to put on a B/L. i dont know about yoda's but i've heard that with B/L's you start to have problems....
if i do the L/C coils how much gas mileage would i lose?
Old Feb 18, 2007 | 02:30 PM
UNR.Grad's Avatar
OME can be CV boot killers, the struts are too long for 3rd Gens. The ride is pretty jarring. The front I would def. go OEM but for the rear OME works fine.
Old Feb 18, 2007 | 02:41 PM
I have been getting decent(IMO) gas mileage with my LC coils. I have 3.90 gears,33x12.50 tires and I have been getting about 16.5 mpg in the city and 17-18 on the highway.
Old Feb 18, 2007 | 03:08 PM
CDUFF7's Avatar
Daniel
I was curious what brand your rims are and what is the amount of back spacing that you have?
Old Feb 18, 2007 | 05:52 PM
I have 15x8 steelies with 4" backspacing. I bought them from www.wheelersoffroad.com .
Old Feb 18, 2007 | 06:50 PM
CDUFF7's Avatar
I bet the truck looks great on those rims especially with the 33's. Thanks for the info.
Old Feb 19, 2007 | 08:56 AM
99SR5's Avatar
even with a diff drop bracket?
Old Feb 19, 2007 | 09:08 AM
FUZION's Avatar
From what I've seen with a 2.25 or less lift up front, a diff drop bracket isn't always necessary but recommend. To fit 33's you don't have to go any higher up front. Have you looked at Toytec's lifts. I haven't even gotten my next runner yet but i've been racking my brain on trying to compare the Toytec OME3run lift and the tundra/890 lift. I guess I'll be going with whichever is less expensive.
TUNDRA/890 LIFT
Toytec LIFT
Old Feb 19, 2007 | 09:15 AM
99SR5's Avatar
yeah i was looking at that same toytec lift actually and ill probably end up buying the cheaper of the two. they both look very good.
nvdesertrunner
May 11, 2020 08:18 PM
Swim
9
Jan 4, 2016 10:47 AM
Sep 4, 2015 09:27 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
4Runnin2000
Jul 29, 2015 06:09 PM
