OME LIFT- Comfort or Normal shocks?
guys-
im purchasing an OME 3" setup from toytec and am running a TJM bumper upfront, and possibly drawers in the back...when i build them. Im gonna do the 882/891 combo for springs, but was wondering thoughts on the shocks.... who's gone comfort vs. normal and whats better? i do 90% onroad/hwy driving...
also, planning panhard drop bracket and front diff drop... any other suggestions?
thanks ahead of time!
I did the N91SC comfort valved shocks with the 882 coils about 6 months ago. Even though they're listed as "comfort" shocks, don't expect a plush ride with them. My setup is firm and very controlled and the ride is nice over nearly all surfaces. I don't have an aftermarket bumper, which may make a difference, but my guess is that the firm shocks would be very harsh! My recommendation would be the comfort shocks.
I too got the N91SCs upfront and im glad I did not get the normal ones as I believed they would be very harsh. I have N86 in the back with 891 springs. No complaints
Instead of the 882's you might want to consider the 883s. They much thicker coil with a higher spring rate and they don't sage like the 882s tend to do. I have a ARB with a winch and run the 883s with the OME normal shocks and th ride is actually pretty smooth.
I run the normal shocks/struts all 4 corners. Tundra coils front/OME 890 rear. I wish I would have gone with the Comfort shocks, mainly in the rear. The front feels nice, but the rear is a big pogo stick like. Too bouncy/harsh for my taste, but I don't currently have a spare or trailer hitch back there. I think with some weight in the back they would be fine.
if the car feels bouncy, then it means that the shocks are underdampened for that spring. I don't know if the difference in the normal and comfort shocks are in the compression or the rebound, but in either case if bounciness is the issue, you may need to start thinking about changing the springrates. Going to a softer valved shock will only make the problem worse
Peevedkitten
11
Aug 31, 2015 06:57 PM
punks_is_4x4
Aug 21, 2015 01:35 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
i went comfort since its my DD to and from work and the occassional weekend warrior stuff.
