OME leaf pack questions.
Old Feb 11, 2004 | 02:00 PM
GRNTACO's Avatar
Question OME leaf pack questions.
I have some OME leafs that I am going to install but I think I should remove some leaf packs or a overload.
I have a 2001 standard cab with the 2.7 and have no weight in the rear. I want to keep the flexyness that the stock leafs have.
Anyone have the same leafs on a Taco?
Old Feb 11, 2004 | 05:02 PM
cruizin01's Avatar
Yup I got some...I assume your gonna lift the front also? I only removed the extra load leaf on the bottom. I think I got about 3.5 to 4 inches of lift. They flex out to the shock limits so flex isn't really an issue. Did you order the front bushings from toyota for the new springs?
Old Feb 11, 2004 | 05:21 PM
85runner's Avatar
I'd pull the overload and test it. Then remove leafs as needed.
Make sure that your shocks aren't limiting travel. I'd remove the shocks, flex it out and take measurements.
Old Feb 11, 2004 | 06:50 PM
GRNTACO's Avatar
I got the front covered. I got new bushings but not from Toyota they came with the OME stuff.
Old Feb 11, 2004 | 06:54 PM
GRNTACO's Avatar
Front bushings? I got new ones for the OME struts and coils. Is that what you are talking about? Also did you use your stock U-bolts.
Old Feb 11, 2004 | 06:56 PM
cruizin01's Avatar
The front bushings arent available through OME, only the ones for the upper and lower shackle bushings on the rear.
Old Feb 11, 2004 | 07:01 PM
cruizin01's Avatar
The front bushings for the rear leaf springs is what im referring too. They are a steel sleeved' one piece bushing. You can buy a new pair from toyota for like 25 dollars. I hear trying to get your old ones out to reuse can be a real PIA.
Yeah you can use your stock U-bolts. What shocks are you using?
Old Feb 12, 2004 | 06:55 AM
GRNTACO's Avatar
N91SC for the front and N94 for the rear.
Old Feb 12, 2004 | 09:03 AM
cruizin01's Avatar
Thats fine those are the ones that Im running. I just asked becuase if they were any longer you would have to extend your brake line but you should be fine with those. If you have any other questions let me know. ~D
Old Feb 12, 2004 | 03:43 PM
GRNTACO's Avatar
Right on, thanks.
Old Feb 13, 2004 | 01:05 PM
GRNTACO's Avatar
Now I know what bushings you are talking about the fixed eye bushings. I didn't get those and they were suppose to be included in the kit. I hope to see them monday.
ZGjethro
Jun 7, 2017 11:04 PM
ktm192k
Oct 1, 2015 08:47 AM
Brodetski
Sep 30, 2015 11:50 PM
oldblue
Sep 28, 2015 04:07 PM
83
Sep 27, 2015 04:13 PM
