OME Leaaannnnnnnnnnnnnnnnn -
Old Mar 3, 2005 | 06:56 AM
payyourtoll's Avatar
1/2 the time the stickers are wrong
Old Mar 3, 2005 | 09:35 AM
Stegall984R's Avatar
From: OmG, Hi2U !!! .... DANG, my chic's got some SEXY eyes.... among other things. WOOT WOOT !!
on my rear springs the taller one was labled " A ", the shorter one " B "
I put the taller one on the driver side, but even with a full tank of gas, the passanger side sits a inch lower. sucks.
whats the cost on the trim packers ?
Old Mar 3, 2005 | 09:51 AM
GodwinAustin's Avatar
$10 or so - the PIA is taking the assembly back apart
Old Mar 9, 2005 | 04:25 PM
Originally Posted by TDiddy
The rear coils are obviously different lengths, never noticed much difference on the fronts though. We did give the fronts a good look and did pick the one that looked slightly taller for the DS.
I looked, took a good look, at the 880s and really couldnt see a difference in height btwn the 2 coils....plus they definetly are not marked for DS or PS - I figure it might be different for the 880s than with the 881 or 882?
Old Mar 9, 2005 | 04:39 PM
  #25
HOJU's Avatar
length might not be too different, but I bet the spring rate is...
Old Mar 9, 2005 | 04:42 PM
  #26
if thats the case; either OME forgot to mark mine or maybe you're supposed to guess
Old Mar 9, 2005 | 06:23 PM
  #27
X-AWDriver's Avatar
What causes the lean? I haven't heard this issue with Bils/PP setup or is it common with those too?
Old Mar 9, 2005 | 06:27 PM
  #28
I think its more a taco thing....
to add to all this I talked to Wheelers and they said they had asked ARB/OME the same question about all this DS/PS coil stuff...AND ARBs resposne was that they do NOT purposely make one coil in a set longer than the other....so there you go, apparently it happens, but it is not because ARB intends for it to
Old Mar 10, 2005 | 05:17 AM
  #29
Did anyone have to grind down the OME trim packer at all to make them fit the front shock seat?
Old Mar 10, 2005 | 05:23 AM
  #30
nope. It will fit snug over OME shocks.
ZGjethro
Jun 7, 2017 11:04 PM
Scottcrb
Mar 3, 2016 11:57 AM
A2theK
Oct 14, 2015 07:10 AM
Swampwalker
Oct 12, 2015 09:49 AM
justdifferentials
Sep 5, 2015 06:52 PM
