Ok to get Snorkel...
Old Jan 31, 2004 | 07:00 PM
  #41
SkyRat's Avatar
Not to Hijack.... But,
I don't think the "pressure plug" of having the exhaust submerged can overcome the exhaust gas pressure, can it?
Is there any danger in getting in deeper than the exhaust?
Old Jan 31, 2004 | 07:06 PM
  #42
44Runner's Avatar
Originally posted by 4x4Lamm
I don't think I started it but I said it, cause it is true. The primary function of a snorkel it to get a better airsourse to the engine, i.e. Cleaner, Dryer and Colder but if you check the ARB website or read up on the safari snorkel the "ram air" performance gain is stated as being true. ARB has not ever given me a reason not to belive them. The thing is though, you can't dyno test ram air so I guss there will always be a disagreement between the skeptical and those that understand physics/aerodynamics. No hard feelings, just gotta go with what I know.
Even if this were true, the air being "rammed" in would go out the same holes the water does. Take a close look at the picture above. Trust me, any extra ram air power that might be made isn't even enough to over come the extra drag created by the snorkel tube itself. You are dreaming. The only people that I have heard talk about this ram air effect are all people that don't own snorkels.
Old Feb 1, 2004 | 02:29 AM
  #43
Yoter's Avatar
Guest
Importers got the same kinda idea
They have their cold air intake kits that breathe from the lower scoop. Sucking the air from outside. Snorkels seem to have the same idea but the difference being they suck from above the rig for the purpose of not getting water. Are they the same in a way?
Old Mar 24, 2004 | 11:25 AM
  #44
shazaam's Avatar
Originally Posted by INsr5runner
wow I missed this post!
here is the part# for the taco piece ss170hf
Make sure your woman knows what it's gonna look like, and that EVERYONE will give you the "what the hell is that" look.
My girl hates the snorkel, but she isn't really into offroading, and she is superficial! :pig:
Anyone have a part number for the tacoma pipe? and where to get it cheap? thanks
Old Mar 24, 2004 | 11:35 AM
  #45
TDiddy's Avatar
Gotta agree with Dave, I can't buy the ram-air idea at all. In order for it to be a true ram-air system, wouldn't the snorkel have to connect directly to the carb (or throttle body in this case)? A snorkel simply moves the air opening up above the fender, right? It still connects to the air box, so air goes through the filter? Seems just as restrictive as a stock setup. If anything I'd think that the deckplate mod would be more "ram-air"-like than a snorkel.
Old Mar 24, 2004 | 11:51 AM
  #46
shazaam's Avatar
Yeah I don't know about the whole ram air thing. I ordered a snorkel last weekend, and now I just need the part number for the taco piece to make this work. So instead of starting a new thread I thought someone who has done it already could just post the part number on here too.
Old Mar 24, 2004 | 12:25 PM
  #47
WolfpackTLC's Avatar
Funny... I have a 96 and I didn't need the Taco part you guys keep referring to... hmm.
Old Mar 24, 2004 | 04:39 PM
  #48
Hyperlite's Avatar
96 and 97 4Runners already have this "Taco" part...
Old Mar 24, 2004 | 04:55 PM
  #49
shazaam's Avatar
aaaarrrggghhhh ... does no one have this part number?
come on guys don't make me go to the dealer and deal with them
Old Mar 24, 2004 | 05:03 PM
  #50
Hyperlite's Avatar
If you want it cheep then go to a junk yard, if not got to the guy at the stealership and ask him to look up an air intake part for a 3.4L Taco. He will pull up a diagram of the parts in the intake. There will be a airbox with an 90 degree elbow. Attached to that is a pipe that runs above the passenger wheel, this is what you need to buy.
Old Mar 24, 2004 | 05:05 PM
  #51
shazaam's Avatar
Thanks hyperlite
Old Mar 24, 2004 | 05:25 PM
  #52
AznSky's Avatar
Dood, just call mike. He should have the #
Old Mar 24, 2004 | 05:26 PM
  #53
shazaam's Avatar
I pmed mike .. didn't get an answer
Old Mar 24, 2004 | 06:12 PM
  #54
Firefyter-Emt's Avatar
Hey, I was just checkin in, figured from your pm that a snorkle post had to be up close to the top.. I notice you have a 3rd gen truck... Once you get in your kit (or if someone else knows.) Make sure you need my hole saw size.. Mine is a 83mm or 3-1/4" 44Runner may know, but I do know this is the right size on the 2nd gen truck though..
Old Mar 27, 2004 | 05:03 PM
  #55
shazaam's Avatar
ok I got the tacome intake extension today. But how does it go on? I see the air box connecting to the round hole in the fender wall. and I'm guessing there is a 90 degree bend back there where I would then attach the taco pipe to. But how do you get behind the fender to access the open end of the 90 degree angle piece?
I hope I'm making sense. thanks guys
Old Mar 27, 2004 | 05:49 PM
  #56
AznSky's Avatar
Do u actually plan on cutting the hole urself? Cuz if u make a mistake, the error could be permanent.
Old Mar 27, 2004 | 06:23 PM
  #57
shazaam's Avatar
It's not "could be" permanent. "It is" permanent. But yeah if I can cut people open, the truck shouldn't be that much harder. But don't worry I've got a few TTORA guys coming over next saterday to help me out. Were going to do another taco as well.
Old Mar 27, 2004 | 08:06 PM
  #58
44Runner's Avatar
Just a question, who the hell else would he have cut the hole?
Short of mental retardation, anyone can do this mod and it should take no longer than an hour. They provide a nice little stencil so you won't mess up and if you do, well, you connect the dots.
sdastg1, you got the right idea man. Just pull out the black fender lining to get in there.
Lee, if memory serves I am 99.9% sure that is the same size I used.
Dave
Old Mar 27, 2004 | 08:50 PM
  #59
shazaam's Avatar
Thaks Dave
I looked both here and 4x4 wire, the correct part number wasn't posted anywhere. I went to the dealer and thanks to the nice diagram that was posted here I was able to point out the part on the screen. I'll post the correct part number on here for the next time some needs to do this tomorrow.
Also where do I go to get the 02 sensor safe sealant. Advanced auto, home depot, NAPA?
thanks
Old Mar 27, 2004 | 09:10 PM
  #60
AznSky's Avatar
Didn't u do the deckplate.............oh wait, u got one of the coool cold air intakes that suck water in like crazy!!
Yeah u can get the sealant at any auto parts store. Just make sure it says sensor safe.
