Oil temp Gauges
Old May 9, 2003 | 08:55 AM
SteveS's Avatar
Oil temp Gauges
I'm wanting to install an engine oil and trans oil temp gauges. I was wondering if anyone has done this? I mainly need info. about how and where to install the sender units.
I have a 2001 Tacoma V6 with auto trans.
I'm mounting the two gauges in the Lo-tek A-pillar pod unit.
If I need to I will install both a remote engine and trans filter for a good sender port. I'm not worried about leaks in the lines, but since I use my truck in the backcountry I worry about damage (leaks) to the filters. If anyone has info, or the Pro's & Con's to remote filters, I'd like to hear about it.
Thanks
SteveS (aka ZR2Steve)
PS This is my first post here, and I did a search, but didn't come up with this info.
Old May 9, 2003 | 01:30 PM
FattyCBR's Avatar
I have a tranny temp and oil pressure gauge so this should work for you.
For the oil temp if you look just to left of the oil filter there is a little hex plug in the block, there is also the stock oil pressure sender directly above it. You can remove that and then install your sender in that port using an adapter (I bought a brass adapter from NAPA).
For the tranny temp I tapped into the line going to the transmission cooler, make sure you use the line before the cooler so you get a true reading. What I did was go to NAPA and buy a brass T fitting. Then I bought two nipples that fit the transmission hose and screwed into the T fitting. Last I used an adapter to screw the the sender into the T.
HTH
Old May 9, 2003 | 02:27 PM
BajaTaco's Avatar
Re: Oil temp Gauges
Originally posted by SteveS
... PS This is my first post here, and I did a search, but didn't come up with this info.
Damn newbies!
Actually, I know this d00d and he is the 007 of the expedition back country realm this is the chap responsible for bringing us the "full-time power outlets" mod.
If I ever get off my butt, you will get to see some more of his stuff on my website, at..
http://www.bajataco.com/zr2steve/ZR2Steve.html
good to see ya around Steve
Old May 9, 2003 | 08:21 PM
Gadget's Avatar
This might help:
http://www.gadgetonline.com/gauges.htm
Gadget
www.GadgetOnline.com
Old May 10, 2003 | 06:18 AM
SteveS's Avatar
Thanks guys
Let me digest this for a while and see how it works out for me. The engine looks like a slam-dunk. I also adding a engine oil pressure switch to a buzzer, so thanks for adding that info too.
I stopped by Toyota last night at see about buying new trans fittings and modify those, but at $30 each, I may just tap the hose as you did.
Love the ground tip. I'm sure you saved me some time there.
Thanks for the plug Baja. I hope I can add useful info at some point.
the1998sr5
15
Jul 14, 2020 08:35 PM
gary4runner
Sep 24, 2015 12:53 AM
Nickyodaman
Jul 27, 2015 12:13 AM
88yodabasket
Jul 13, 2015 01:32 PM
Poncho0206
Jul 10, 2015 06:21 PM
