Oil Pressure Sender... Frustrations....
Old Feb 15, 2004 | 01:01 PM
hub_01_69's Avatar
still having issues with removing my stock sender....1 1/4" socket was too big and a 1" was too small...i got a 1 1/16" socket on there but it slipped....metric maybe? neone know the exact size because i'm prolly gonna have to buy a socket to fit it if i can figure out the size... any other ideas to get this piece out?
thanks
hub
Old Feb 15, 2004 | 01:14 PM
Krash's Avatar
Um, I tried finding my autozone cheapo manual to the truck but couldn't find it. Might want to just go up there and look in one of their manuals then go buy a socket. or ask them for a dummy light sensor and match a socket to it. Just reccomendations.
Old Feb 15, 2004 | 01:59 PM
hub_01_69's Avatar
i somehow managed to get an adjustable wrench on it and i've got the other installed and hooked up...but my gauge is still dead on the H
Old Feb 16, 2004 | 06:05 PM
hub_01_69's Avatar
c'mon guys don't leave me hangin
Old Feb 16, 2004 | 06:15 PM
  #25
Krash's Avatar
For some reason I remember reading something about a wire or something similar inside the gauge that the indicator gets caught on. Its been a long time since I read about it but do a search on 4x4wire, thats where I remember reading about it.
Old Feb 17, 2004 | 02:08 AM
  #26
foxtrapper's Avatar
Guest
Chanel lock type pliers will work just fine to remove the unit. So too will reaching under it with the appropriately sized open end wrench (10mm as I recall).
thanks
hub
Old Feb 17, 2004 | 11:35 AM
  #27
rami's Avatar
as for the size of the socket to remove the sender, i recently
did mine (I have a 2L diesel though). It took a 27mm deep socket
to remove it. Oddly the new sender I got from Toyota
took a 24mm deep socket to install..
I know a guy with an MR2 (not sure the year or engine) and I know
that sender also takes 27mm, so 24 or 27mm is a good bet..
hope this helps..
Rami
Old Feb 17, 2004 | 12:08 PM
  #28
pasteurized's Avatar
That reminds me, it is for sure a 27mm deep wall. The Napa store I work at didn't even have one in stock, I had to order it from the Distribution Center. Now I have a 27mm deep wall socket I'll probably never use again :pat:
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
