oil pressure
Old Feb 28, 2004 | 06:07 PM
slammdrider's Avatar
oil pressure
i have a question i have an 84 toyota pickup with a 22re efi engine and the oil pressure is really low when ever you drive it. is that just a trait for an 84 toyota or does something need to be replaced i just wanted to make sure that there could be a chance its just a trait for that year of truck before i go spending money to replace something.
Old Feb 28, 2004 | 08:38 PM
amusement's Avatar
Oil pressure should be between 36-71 PSI @ 3,000 RPM.
At idle it's about 3-4 PSI.
As you can see low oil pressure while driving is a problem.
It's possible the oil pressure sensor is failing and providing incorrect info.
Suggest you replace the oil sensor.
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
