Oil capacity in a 3.4
Old Feb 25, 2005 | 04:00 PM
ScottyBean's Avatar
I was on 4x4wire, and someone had a post about how much oil a 3.4 can hold. Since im not registered there, I deceided to post it here, because they are all saying that theirs take 5.5 qts and is exactly on the full mark.. Well i can put 6 qts on mine and its still a little bit lower than full.. what gives?
Old Feb 25, 2005 | 04:03 PM
Localmotion's Avatar
meh...i just put it in until it hits a little below the second dot on the dipstick.
matt
Old Feb 25, 2005 | 04:17 PM
rearviewmirror's Avatar
I just changed my oil and put the 5.5 qts. in... low and behold today I added nearly the rest of the last quart to bring it up to about 5.9 qts.
Old Feb 25, 2005 | 06:09 PM
4-RUNNIN' FREAK's Avatar
Same for me. When she was new I used 5.5, but now it's a full 6 and it's in the middle. I DO let it drain a lot longer now though. Used to be 5 mins now 30 mins.
Old Feb 25, 2005 | 06:20 PM
Ironmike4x4's Avatar
From what my training technician taught me was that you are "supposed to change oil at operating temperatures that way the oil sludges and dirt has not yet sunken yet to the bottom of the pan." Also when you fill the oil and check the dipstick the oil must also be at operating temps. so that the readings are more accurate.
Old Feb 25, 2005 | 07:40 PM
EDIT: I did start doing mine while hot too when I started 30 minute drains. That makes some more sense. t/y
Old Feb 26, 2005 | 07:14 AM
krasher's Avatar
The last oil change I had I put in 7 quarts. It filled it middle of the stick.
I have 161k on my TuRD.
Old Feb 26, 2005 | 07:23 AM
ugadawg95's Avatar
I put in 6 qts. It looks a little high after I check it the first time, but at operating temperature, it reads dead on.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
93toyoguy
Aug 2, 2015 07:41 PM
WellsR
12
Jul 31, 2015 03:27 PM
1996Taco
Jul 20, 2015 12:02 AM
Nickdigg
Jul 7, 2015 06:04 AM
