OEM valves and seals
Old Jun 22, 2004 | 08:19 AM
TRunner's Avatar
When replacing these, should they all be OEM? I am pricing OEM as more then $9 per seal. Where I can get them from BAP\GEON for only $1.40 per seal.
Old Jun 22, 2004 | 11:49 AM
TRunner's Avatar
Anyone?
Anyone?
Anyone?
Bueller?
Seriously... I need some kind of answer on this as my heads are waiting for me to get the parts.
Old Jun 22, 2004 | 01:13 PM
TOR
On these you get what you pay for. Here is the best I could do for you man.
90913-02094 intake seals $5.17ea
90913-02091 exhaust seals $4.70ea
Anyone?
Anyone?
Anyone?
Bueller?
Old Jun 23, 2004 | 05:43 AM
TRunner's Avatar
Almost half of what the other dealers want. What about shipping?
What about head gaskets? and other seals and gaskets I will need for the rebuild?
Does the dealer replace head bolts? I think the Haynes repair manual claimed you should reuse them.
Old Jun 23, 2004 | 05:55 AM
roger's Avatar
I don't think reusing head bolts is a good idea. If they are stretched out (likely at this point) you will probably blow a headgasket in the very near future and have to do this all over again.
While I have little experience with Toyota gaskets, my experience from working on other makes is that the OEM seals are almost always superior.
Bottom line: spend the extra money, do the job right the first time, it will save you headaches and money in the long run.
Old Jun 23, 2004 | 06:07 AM
TOR
Vin
Send me your VIN and I will quote you whatever you need or want for your vehicle. This will just ensure we are on the same page.
On shipping, I try to stick to $6.00 if the package isn't over 3 or 4 lbs. That is shipped UPS ground and would probably reach you within a day since you are in Texas. All packages over $300 shipping is on me. Send me that VIN and we can get started.
TP
Old Jun 23, 2004 | 07:17 AM
TRunner's Avatar
I actually can't get you that info right now, but I can tell you this:
4Runner
3.0L V6
4x4
Limited Edition
Transmision cooler
Tow Package
That should tell you just about everything you need to know and then some. If you still need the VIN, then I will have to get that tonight, but I could realy use the prices today.
Old Jun 23, 2004 | 07:34 AM
SLC Punk's Avatar
I will always use OEM stuff when it comes to seals. I will never re-use head bolts even if the manual says its ok.
When I got my Celica's top end rebuilt, I went all OEM Toyota except I went with ARP head studs, since they are stronger.
Old Jun 23, 2004 | 01:43 PM
TOR
Here is a list of things you might replace while doing your heads.
11116-65032 head gasket $51.50
11115-65033 head gasket $51.50
90311-42024 cam seal $4.32 ea x2
11213-65010 valve cvr gasket $8.71 ea x2
13568-69075 timing belt $23.35
90311-40022 crank seal $4.32
90311-92006 rear main seal $16.08
Hope that helps!
4Runner
3.0L V6
4x4
Limited Edition
Transmision cooler
Tow Package
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
kouki420
Sep 2, 2015 11:42 AM
ethanethan
Engine Swaps
Aug 11, 2015 09:09 AM
mbomberz1
Aug 8, 2015 06:57 AM
andrewtexas123
Jul 14, 2015 04:29 AM
