O2 Sensor stuff!!!
Old May 15, 2005 | 07:39 PM
Brew's Avatar
O2 Sensor stuff!!!
Im looking to run a 24:1 mixture (dont ask)
How would I go about setting my O2 sensor to allow my 1991 Toyota Pickup 22re to run like that?
Thanks,
Bill
Old May 15, 2005 | 08:58 PM
jimbo74's Avatar
24:1 mixture of what? gas/oil? you wouldnt set the o2 as you wouldnt run it... its not a 2 stroke engine.....
Old May 15, 2005 | 09:07 PM
Brew's Avatar
24:1 Air/Fuel Ratio
Old May 15, 2005 | 09:10 PM
jimbo74's Avatar
firt of all i think asking would help figure out what to do... why dont you jsut bypass the o2 sensor?
Old May 15, 2005 | 09:19 PM
Brew's Avatar
Maybe just a simple A/F Controller?
Old May 15, 2005 | 09:54 PM
superjoe83's Avatar
i really doubt that a 22re would even run on a 24:1 air/fuel, thats way too lean, most EFI systems lean out to around 17:1 when cruising, but 24 is too much in my opinion
Old May 16, 2005 | 12:24 AM
84sr5yoty's Avatar
24:1 will burn the valves in no time unless you use some really wicked water injection system.
Old May 16, 2005 | 03:58 AM
Brew's Avatar
It wouldnt hurt the motor if the spark was hot enough to completely burn all of the A/F inside the cylinders.
This is a project im working on anywho.
Old May 16, 2005 | 06:19 AM
midiwall's Avatar
Figuring that you know the issues of trying to run this lean, then the only thing I can think of to make it happen is the Split Second FTC-017E controller:
http://www.urdusa.com/Merchant2/merc...ory_Code=SPLIT
Outside of the normal functions of letting you modify timing and fuel delivery, it'll also fake out the O2 feed and force the ECU into open loop during cruise. That'll stop the ECU from trying to force a Stoich A/FR and let you tune during what would normally be closed loop.
Good Luck!
krimsonone
Sep 13, 2024 09:33 AM
Regency
20
Jan 3, 2020 07:43 PM
montanatruck
Feb 26, 2017 07:07 AM
JHalcyonM
Aug 4, 2015 01:19 PM
terminator
Jul 27, 2015 07:13 PM
