O2 Sensor diagnosis
Old Jan 25, 2004 | 05:18 PM
Dropwise Dunkle's Avatar
O2 Sensor diagnosis
Does anyone know how to test an Oxygen Sensor?? And if it's bad, where is the best place online to buy one?? Muchas Gracias!!
Old Jan 25, 2004 | 05:31 PM
Fink's Avatar
Welcome to the board man!
Not sure how to check if its bad...but if you have a Check Engine Light on and are noticing performance decreases then its most likely bad...I would only go stock for the 02 sensor.
Fink
Old Jan 25, 2004 | 05:33 PM
MTL_4runner's Avatar
Re: O2 Sensor diagnosis
You can either probe the voltage when the engine is running or get an OBD reader like mine which will give you the output of all the sensors onboard the vehicle. Check my sig for details.
I would get an OEM sensor but there are some aftermarket available online too.
Old Jan 25, 2004 | 10:55 PM
GoudyMan's Avatar
use "search"...... somebody put up a website earlier on where to get 02 sensors for cheap!
Old Jan 25, 2004 | 10:59 PM
tenfourtyeight's Avatar
OxygenSensors.com.
Get the 'universal' O2 sensor, then plug it in where the stock one was, using the stock hardware.
Old Jan 26, 2004 | 04:23 PM
EWAYota's Avatar
whats the voltage reading suppose to be on a o2 sensor??
Old Jan 26, 2004 | 04:35 PM
juicyfruity's Avatar
A good working O2 sensor should have a voltage that fluctuates between 200 and 800 mV. If it fluctuates in a narrower range (400 to 600mV), it means it's going bad.
remember to test the O2 sensor under normal operating temp, when under closed loop.
oh yeah, using an Analogue Multimeter would be better because digital multimeters can be slugish because of their low sample rate.
Old Jan 26, 2004 | 05:00 PM
I can't say I agree with this info at all. Yes, the sensor should be between 0 and 1volt anything outside that should trigger a CEL. An engine management system can fluctuate quite a bit or barely at all, so just stating 0.4 to 0.6V, you may throw out a good sensor. It also depends on which sensor you are looking at. The sensor in front of the cat varies alot more than the one behind the cat. A truly malfunftioning O2 sensor will almost always trigger the CEL. You can still replace and see if it helps as well.
I have never seen an analog meter beat a digital one. Maybe the older digitals were slower but I have never had trouble capturing the variation in voltage on a DMM.
If you really want to see the readout from the sensor well use the OBD II reader in my sig.
Old Jan 26, 2004 | 07:02 PM
This info was taken from the Toyota Service Manual...
Have you ever compared the readings from a Digital and an Anologue multimeter? You can't beat the response of an anologue multimeter.
Good to see a french(?) canadian on the board!
ps: he might not have OBDII, (started in 96) so he won't get a
check engine light
The one behind the cat is TOTALLY irrelevant to closed loop a/f control. It will only compare the reading with the front one to verify if there's more o2 (in %) present, so less unburt hydrocarbons...
jb451
7
Oct 7, 2022 06:58 AM
Bourbonblues
Dec 15, 2017 05:43 PM
Kreedy1
Sep 8, 2015 06:33 PM
zz_denis
Sep 6, 2015 03:43 PM
moparbay
Sep 3, 2015 12:48 PM
