O2 Sensor on 2001 Rav4
Old Dec 31, 2004 | 07:56 PM
Back40's Avatar
Question O2 Sensor on 2001 Rav4
Anyone ever replace an O2 snesor on a Rav4? Ran over to Autozone to check the code (check engine light) and got a PO420 which is Catalyst System Efficiency below Threshold. The Autozone guy suggested an O2 Sesnor but he couldn't tell which one. There are 2 on the exhaust manifold. Then he looks it up the price and says $459.00 each! The other Autozone guy suggested I clean both sensors with brake cleaner. I plan on checking with my local Toyota parts dept Monday but just though I'd ask for feedback.
Old Jan 1, 2005 | 04:04 AM
MTL_4runner's Avatar
That sounds more like a catalytic converter than an O2 sensor.
If you need a new one, just get an aftermarket (an OEM is huge $$$$).
Old Jan 2, 2005 | 03:03 PM
Toytech's Avatar
You need get have the ECM reprogramed, there is a tsb on it. And I think OEM 02 sensor are only around $150, or $250 if it's an A/F sensor.
Old Jan 2, 2005 | 03:21 PM
Funrunner's Avatar
I threw a CEL on my Toy truck and it turned out to be a Code 21 (O2 Sensor). I had to have a mechanic check it since the auto parts store can only do 96 and newer vehicles. The total was $326.88. The sensor itself was $197.11.
If you can do the work yourself I highly recomend it. Good luck.
The truck is still running bad and has to go in again. ugh. More $
Old Jan 2, 2005 | 04:01 PM
Just do a search and you'll get a good idea for what this code means:
I did the search and here is what I found
Pretty much what I said above.
Old Jan 3, 2005 | 12:13 PM
Back40's Avatar
Is there a link to the Toyota tsbs on this site? Thankis!
jb451
7
Oct 7, 2022 06:58 AM
sanctfy
Sep 13, 2015 06:33 PM
EatChipsNow
Sep 9, 2015 01:25 AM
Kreedy1
Sep 8, 2015 06:33 PM
moparbay
Sep 3, 2015 12:48 PM
