O2 error from computer
Old Apr 27, 2004 | 09:34 PM
david in germany's Avatar
Ok I have had this reoccuring error in the 4runner I have changed the O2 sensor 2 times now and after 1 day it gives the error again.
Anyone have an Idea why this would be happening?
David
Old Apr 27, 2004 | 09:46 PM
superjoe83's Avatar
Probably the wiring from the o2 sensor to the computer is damaged in some way, or the connector on the o2 may not be making a good connection, hope this helps
Old Apr 28, 2004 | 03:54 AM
MTL_4runner's Avatar
David
What error are you talking about?
Is this an OBD code? If so, what was the actual code number?
Old Apr 28, 2004 | 06:13 AM
It is for the o2 sensor (off hand I think it is a 5)
David
Old Apr 29, 2004 | 10:30 AM
David
What are the specs on the truck?
Year, engine, etc
Old Apr 29, 2004 | 09:24 PM
Year, engine, etc
1987 4runner with 22re rv cam and headder,
David
Thanks all!
Old Apr 30, 2004 | 06:42 AM
PirateFins's Avatar
David,
I had the same problem on my 92. The wire harness for the 02 sensor goes accross the truck along the cross member. Check the section right underneath the exhaust pipe. My exhaust pipe had touched the wire loom where it is wrapped with a thermo protection wrap. So the damage was not visible. I removed all of the covering, spliced the wires together, wraped all wires indvidually + together, and put all of the protective covering pack on. Worked like a charm. Don't know if that is the case with yours but it a place to check.
kawazx636
Oct 6, 2021 03:03 PM
some drunk guy
Aug 3, 2021 06:09 PM
dbollier123
Sep 29, 2015 05:23 PM
