noob lift help
Old May 26, 2004 | 04:57 PM
slimtim's Avatar
Question noob lift help
in the next 2 weeks my car will be sold and i will have a 2cnd gen yota (i think its second gen a 91) and i am concidering a suspension lift, i've read up on OME lifts and all that whatnot, but with all the money i'll have i wanna do this nice even though i'm leaving it IFS, i dont wanna loose any type of ride comfort, but possibl;e impreove it. I've become focused on a 4 inch lift, i dont like the idea of a 4 inch body lift and anything less than 4 seems pointless for suspension lift, the prob is i want some nice shocks, heres what i've been looking at
PROCOMP IMX6
I can get these specificly for my toyota with a 3-4 inch lift for $350 or a 2-3 inch for $350, or $95 a peice. I love the idea of these becuase they have a 6 setting adjustment on them, if i dont like the handeling i can "adjust" the stiffness, this particular product seems relativly new and reviews where hard to find, but what i did find people aproved of them.
6-position adjustability for compression and rebound.
300psi Nitrogen gas charged.
Velocity sensitive disc valve system.
Inverted mounting capability.
14mm super polished, hard-chromed rod.
51mm shock body diameter.
Single piece banded piston.
Epoxy finish with 300-plus hours salt spray durability.
BILSTEIN Heavy Duty Shock
around $70 a peice, w/ no particular ride height specified
Superior Monotube Design & Fabrication!
Rising Rate Self-Adjusting Working Piston!
Patented Nitrogen Chamber & Floating Dividing Piston!
One Piece Alloy Rod Guide & Seal System!
Digressive Working Piston Assembly Increases Shock Life!
SUPERLIFT Superide Shock Absorber
specified for 4-5 inch lift about $41 a peice
10-Stage Velocity Sensitive Valving for Maximum Control
O-Ring Piston Seal Prevents Fade
Heavy Duty Chrome Hardened Piston Shaft
High Fluid Capacity Twin-Tube Body
High Performance Multi-Viscosity Fluid
Urethane Eye Bushings
Double Welded Eyes
Durable White Enamel Finish
Limited Lifetime Warranty
RANCHO RS9000X Nine-Position Adjustable Shock
I've herd these are okay, but that setting 4 will be too loose and setting 5 will be rock hard, but more comments will be much apreciated, available at $77 a peice, but this articluar website only has 0-1 inch lift advertised.
Tri-tube, mono-flow design yields 17 times greater fluid area than its predecessor, ensuring exceptional performance under a full range of load and temperature conditions
9-position adjustment knob for desired performance curve; firm for off-road, soft for street and mid-range for comfortable highway driving
Cellular gas design with VFC (Variable Force Control) for precise flow metering
Precision-machined construction tough, durable, long-lasting
Double welded loops with red urethane bushings
5/8inch hardened rod double-chromed for long wear
Red convoluted boot for all weather protection
Please comment on wich of those you would pick or advise other shocks, please ride comffort and ability off road is very important
there is another problem, i know i can install a lift, its just that some lifts dont come in complete kits with certain shocks, what am i looking for to install a 3-4 inch lift in this truck? please guide me in the direction and i will answer any questions as needed
here is the website i was looking at for info
http://www.truckperformance.com/prod...ductID=1092912
-tim
Old May 26, 2004 | 06:22 PM
slimtim's Avatar
c'mon what are your thoughts
i cant find really what i'm lookijng for twith the search
what components do i need for the lift besdies shock
TTT
Old May 26, 2004 | 06:49 PM
growinseed's Avatar
You also need a lift kit, spring pack i.e way to increase height of truck. IMO a combined body and suspension lift it better in the long haul do to less stress on drive line/ suspension components. Check out the tech section of YT there is quite a bit of info on shocks and who is using what and why.
welcome
Nathan
Old May 26, 2004 | 06:54 PM
Fink's Avatar
I'd just go with the 4" Pro-Comp lift, it comes with some nice shocks and there are few who have it installed on their rigs here on YT.
Fink
Old May 26, 2004 | 08:24 PM
slimtim's Avatar
Fink
yeah i didnt get much review on the pro-comp shocks from anybody, i'm very interested, and yes i am also thing part body lift, the last thing i need is tons of driveline damage
Old May 26, 2004 | 09:02 PM
slimtim's Avatar
well i've been looking around and i cant find a complete 4 inch lift for the MX-6 procomp adjustables so i was thinking a 2 inch body and a 2-3 inch lift, the problem is i cant find anything for th mx-6, so does anybody know of incomplete suspension lifts w/o the shocks? that way i can buy the lift and then install the mx-6 shocks with it. . . . .i have found incomplete 6 inch lift kits, can i buy that and just put 2-3 inch lift shocks? thnks
-tim
Old May 27, 2004 | 01:14 AM
bikeguy18974's Avatar
Buy one of the complete 4" lift kits. You decide the brand. It will come with what you need to lift your truck both front and back. It should also come with shocks.
If you are set on the mx-6 shocks then sell the ones that come with the kit and get the mx-6's. I haven't looked but make sure they sell the mx-6's for toys w/ a 4" lift before you deide all this.
You also posted a pic of the superlift shocks. If you are considering those get a superlift kit, it should come witht hose.
Old May 27, 2004 | 04:37 AM
AFRunner's Avatar
-tim
4wheelparts.com has the Pro Comp 4" lift with MX6 shocks
http://www.4wheelparts.com/4wp/produ...RO&expand=sub4
Old May 27, 2004 | 07:31 PM
slimtim's Avatar
hey thanks a lot, i actually looked at that site, but it was lat ei must have missed the mx-6's, its too bad i cant find a 2-3 inch lift with tnm, i dont wanna loose power and releyablility with the angles drive lines and a 4 inch lift. . . . . .. ..and i dont wanna buy a different lift and swap the shocks in, but it seems i might have to. . . .
i've changed my mind again to mabe 2 inch suspension and 2 inch body
will i loose power with a suspension lift? cause i live in the mountains with hills all over and i dont wanna be barely tuggin along, and i know the 22re doesnt back an army of punch!
thnks
-tim
Old May 27, 2004 | 10:54 PM
superjoe83's Avatar
Talking
with just a suspension lift, no you wont, but if you put bigger tires on it, yes you will but you will be able to correct this by changing your axle gears to a lower ratio, (higher number) the actual ratio that you shoud go will depend on the tire size you choose
Old Jun 1, 2004 | 04:00 PM
OicnaiC's Avatar
A little suspension and a little body lift is the way to go (IMO) what you have to do is customize your suspension lift to fit your needs, like longer rear springs (the downey kit is awesome), possibly some coil spacers, and some ball joint spacers for the front. Then you measure your travel and pick whatever shock you want. With downey springs (or coil spacers) and ball joint spacers you can get about 1.5" all around lift and then with a 2" body lift on top of that 33" tires fit just fine, you could even trim to fit 35's .
Pocoyota
Sep 8, 2015 02:41 PM
joeynational
Sep 5, 2015 01:54 PM
AkitaDog
Sep 3, 2015 09:01 PM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
