No 4WD light
Old Mar 31, 2004 | 12:47 AM
swan556's Avatar
No 4WD light
does anyone have any idea what causes the 4wd not to work the relay for the 4wd clicks when the transfer is put into 4 hi but no light and no front dif movement?
Old Mar 31, 2004 | 05:04 AM
Marc's Avatar
Year? Model? Type?
Old Mar 31, 2004 | 05:29 AM
Glenn's Avatar
Originally Posted by Marc
Year? Model? Type?
He's got a '92 4Runner.
Old Mar 31, 2004 | 06:57 AM
mastacox's Avatar
Well without hearing anything more, I think it sounds like you 4wd is broken. Could be your ADD went out, since that is where the litlle 4WD light comes from (there's an electrical plug on the front of your diff, I think it's what "determines" if you're 4x4 or not.)
Is your front driveshaft moving when you're in 4x4, or not. If it does move but your front wheels don't, I think your ADD needs work. MAybe a vacuum hose went bad or something (if you're lucky).
Old Mar 31, 2004 | 07:17 AM
Gbost's Avatar
I had the same problem when they did my lift they just forgot to plug somethng back in that acctivated the add when the 4wd was engaged.
Old Mar 31, 2004 | 08:34 AM
Marc's Avatar
There ar 2 vacuum hoses on the front of the ADD actuator. If you put vacuum on the one closest to the diff it should activate the front hub.
Old Apr 2, 2004 | 12:16 AM
swan556's Avatar
what is the relay in the dash that clicks when the transfer is out into 4WD? I keep hearing it .thanks for the info will try to get at this weekend.
Old Apr 2, 2004 | 12:25 AM
superjoe83's Avatar
the relay is activating the vacuum solenoids for the ADD, or at least trying to.
Old Apr 2, 2004 | 09:26 AM
chasmc2's Avatar
When I bought my runner the 4 wheel drive didnt work got it for a good price
layed under the tranny noticed a plug just hanging around. Once I found its home the 4 wheel light in the cab came on and everything locked in.
good luck finding your prob. let us know
Old Apr 3, 2004 | 06:24 PM
swan556's Avatar
found the problem, the dumb @$$ that had it before replaced the heasd and crossed the vac.lines the activate the add thanks to evreyone for the helpful input, very useful.
mskalmus
May 28, 2017 07:51 AM
adammtb
Jul 27, 2015 11:57 AM
Athansinis
Jul 27, 2015 08:38 AM
ripp96
Jul 25, 2015 02:32 PM
TokyoD23
Jul 12, 2015 06:01 AM
