New Steering Rack Bushings = No shaky!!!
I installed some new steering rack bushings that I just bought from WabFab Offroad. My rig no longer shakes at 65-70 mph!!
Everything feels a little tighter as well!
Quite an awesome mod for 30 bucks!!
did you put them on yourself quatro? btw how are ya? how many miles on that truck of yours?
................ like myself cough cough
Ehmm, me, too. Any special tools needed for this? I've been putting this off for way too long. Need to get it done before the snow starts falling. Will be doing the sway bar bushings along with this.
There's really not that much to it.
Step 1 : Order the kit from WabFab
Bushings Kit
The kit is at the bottom of the page.
Step 2 : Look at this walkthrough if you want....I didn't need it as it's pretty straight forward. There are also instructions in the kit from Wabfab.
Bushing Install
Step 3 : Do it MAN!!!
Some of those bolts are on there son! So be sure you have a breaker bar if you got your truck on a lift or something so you can use something that large. I used a baby sledge to beat my bolts loose since I have no lift to put the truck on.
Some things to consider are that it's MUCH easier to move the rack around when your tires are off the ground. You'll need to be able to do this to line everything up and also to take the old bushings out.
You kinda have to beat the hell out of the old ones to get them out though, so don't be scared! The new ones go in MUCH easier though!
Also...there are TWO metal sleeves for one of the bushings. I think that this is a cure all solution because you'll only need one. Whichever one your bolt goes through for that part of the rack is the one you'll need to use. I needed the larger diameter sleeve.
The walkthrough that I've provided a link to is incorrect that you'll need to bore out anything. I think this is what the larger sleeve is the fix for. Maybe TRD vs Non-TRD or 2wd vs 4wd bushings?? I don't know? One will work though!
All in all it took me about an hour to do. Most of that time was getting the bolts loose.
Oh....I almost forgot. The large bolt in the rack requires a 22mm socket on both ends. I didn't have one and used an adjustable wrench. Just be sure you have something that can get around that sucker!
I hope this helps guys.
Bushings Kit
Bushing Install
Quattro - I ordered them through Wheeler's. They are Energy Suspension. They gave me 2 sets, because I guess Tacoma's/4Runners have two different sized sway bars. They told me to send them back which ever I don't use for credit.
The walk through is not even necessary. If you can do the steering rack bushings, this will be a walk in the park. I did this in my last 4Runner and it took 20 minutes, which was mostly used up by undoing the bolts. Basically, unbolt the two brackets, off with the old bushings, in with the new and bolt up. Easy as pie.
guys sorry to be such a noob but how does one examine the bushings for failure-is there anything to see ?
cack you did this? did it improve sterring feel and other things on your 'Coma?
I need to do mine for sure because my center one is tearing. I can see a rubber tear coming out of the sleeve.
Will be ordering one from Wheeler's very soon.
You can examine it by taking off the skid plate and towards the front of the rig from the transfer case.
1uzRunner
63
Nov 10, 2018 03:58 PM
