New Lights
Old Mar 24, 2004 | 03:33 PM
4x4Lamm's Avatar
New Lights
I'm putting 4 100-watt lights on my roof rack this weekend. I have the brackets from Surco, 2 30-amp switches and 100 feet of 10ga. wire. Anybody see any probs with this?
I plan to run the wires behind the rainseal behind the doors then into the engine compartment. Switches will go on center console.
Any Tips?
Lamm
Old Mar 24, 2004 | 03:39 PM
fooddude's Avatar
do you have the relays. Because if im not mistakin you will most likely need some.
Old Mar 25, 2004 | 12:36 PM
4x4Lamm's Avatar
No relays, just big'ol switches. My dad is an electrical engineer and says it will work, I was just checking here.
Lamm
Old Mar 25, 2004 | 12:44 PM
Good Times's Avatar
I think relays would be a wise decision. W/o relays, the power runs into the switches and can run into problems... Relays are always safer but then again if ya got some big 'ol switches that handle the load, I suppose it's all good!
Old Mar 25, 2004 | 06:28 PM
Corey's Avatar
Co-Founder/Administrator
Yep, I see problems.
As stated, you should always use relays.
There is an old post here by me and a newer one by someone else on how to figure out the size of the relay you need for the wattage of your lamps.
Also please see the Tech section, as I have a write-up in there on how to wire up off road lights.
Here it is.
ashersullivan88yota
Jan 18, 2022 05:37 PM
4.34runner88
Aug 11, 2018 10:44 AM
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
