new idle issue problem P0505
Old Sep 5, 2011 | 01:12 PM
Ned's Avatar
Ned
Exclamation new idle issue problem P0505
Well if you read my other post about a 3500 rpm idle, (Topic here) you know the history. I got a used throttle body and swapped them out. Now I am getting a code of P0505. I never got this code before. So I took the original IAC valve off and put it on the replacement TB, but I still get the same code and it idles low/ rough. Any idea why it would just start giving this code when it never did before?
Old Sep 5, 2011 | 02:11 PM
86yotaswampmonster's Avatar
I would take it apart and I clean Every hole In the throttle body and check ur vacuum lines
Old Sep 5, 2011 | 04:32 PM
Ned's Avatar
Ned
yeah, i'm going to do that. It just doesn't make sense to get the code when it never did before.
Old Sep 5, 2011 | 04:43 PM
Ned's Avatar
Ned
Can a bad TPS cause this? If so, I might swap out the original TPS as well...
Old Sep 5, 2011 | 04:58 PM
It might be the tossed. But ill tell u Toyota engines are run so much on vacuum . I have alot prob with vacuum on my truck as well right now.
bigjstang
Jun 2, 2025 03:56 PM
Charecter1
Nov 6, 2023 10:08 AM
smiley52
Jul 11, 2015 05:16 AM
Jnkml
Jul 6, 2015 01:20 PM
