New to Forums - Alarm Question
Old Aug 21, 2003 | 08:10 AM
Desert Wolf's Avatar
Hey guys, just bought a 2003 Double Cab and thought I'd join the party here.
Just one question though. My Taco has a keyless entry system without the VIP alarm. I've spotted them for pretty cheap, but just wanted to know just how hard it is to install. I'm fairly handy, and I've read it's a simple harness plug in. Is there any insights?
Old Aug 21, 2003 | 11:16 AM
dbullock15's Avatar
Its really simple to do. Basicly you unplug one wire and leave it unplugged then you plug the window breakage sensor in and you have a completed alarm. Comes with instructions, its very simple.
Old Aug 21, 2003 | 11:22 AM
Thanks for the reply...So something like this is easy to do?
http://www.brandsport.com/toy-08586-04820.html
Old Aug 21, 2003 | 11:29 AM
rimpainter.com's Avatar
Hey Desert Wolf, good to see another AZ person here. Let me know if you find gas, I need some.
Old Aug 21, 2003 | 11:36 AM
Thanks for the welcome. I've actually been out a bit this morning around the 7th St. and Bell/Union Hills area, and most of the stations are pumping. I topped off my tank this morning at QT at 7th St. and the 101 with no waiting. Just pulled right in and pumped.
Old Aug 21, 2003 | 11:38 AM
Sweet. Thanks. I drive by there every day.
The big question still remains: Does anyone have Super Unleaded?
Old Aug 21, 2003 | 11:39 AM
Nope, but I guess beggars can't be all that choosy. :cry:
Old Aug 21, 2003 | 11:59 AM
Bob_98SR5's Avatar
Desert,
Type in "RS3200" on ebay. I believe i've seen them for $99 there. Brand new.
Take a look at the install manual for the RS3000 on my page: http://www.4runners.org/articles/rs3000 its a downloadable pdf file
From my understanding, the process is the same. Everything plugs together neatly with harnesses but you'll have to run the wires behind panels.
Also, if they say to mount the alarm unit underneath the seat, mount the unit on a piece of 1/2" piece of pine or something similar. Read this thread and my experience:
https://www.yotatech.com/forums/show...ghlight=rs3000
And welcome to the forum.
Bob
Old Aug 21, 2003 | 04:09 PM
dbullock15's Avatar
If you have keyless entry on your truck already all you need to buy is the upgrade to make it the alarm. All the upgrade consists of is a microphone that listens for glass breakage. I got mine on ebay for like $80 or something like that.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2428652237
Thats what I got on ebay and it worked great.
Old Aug 21, 2003 | 04:36 PM
So, it has all the inner working of the alarm, but doesn't become active without the glass break sensor?
Old Aug 21, 2003 | 04:39 PM
dbullock15's Avatar
Yep its all there. Under the dash near the steering column there is a wire that gets unplugged. You can then plug int he glass breakage sensor into a plug that is located under the dash also. The alarm module is located in the kick panel on the drivers side and can be adjusted for sensitivity. It comes with instructions on exactly how to do it.
Old Aug 21, 2003 | 04:40 PM
Great, sounds like an easy DIY then.
Old Aug 25, 2003 | 11:31 AM
Thanks for the link, should be getting it this week.
Old Aug 25, 2003 | 12:38 PM
dbullock15's Avatar
Good deal...let me know if you have any trouble putting it in.
Old Aug 25, 2003 | 08:13 PM
2001Millrunner's Avatar
I've bought it on Ebay and installed it myself. Trust me, it is SO easy. I've never taken my interior apart and it took me 2hrs. No splicing of wires are required, all you do is plug and play, even the plugs are idiot-proof and will not plug into an incorrect one. the instruction makes it impossible for you to install it incorrectly. This has been written for service guys at Toyota dealer, need i say more?
Oh BTW when you get it installed, make sure the glass breakage sensor is set at least 1 over the suggested sensitivity. i believe the defult they recommend is 5..or6.. i cranked it over one more. i tested out the defult setting and it'd not sensitive enough.
Old Aug 25, 2003 | 08:33 PM
Thanks for the vote, I'm hoping to get it done this weekend. I ran across the instructions on the net, and they even detail putting the zip ties on
It's completely idiot proof, but then again, somone will just go ahead and make a better idiot.
Old Aug 28, 2003 | 08:00 AM
Alright guys, thanks for all the help. Received the part yesterday, and took about an hour to put in this morning. Everything works great.
nonstop
Jul 24, 2015 06:29 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
jetspeedz
Jul 13, 2015 09:32 PM
