New Brembo rotors & PF Pads...WOW!!
Old Apr 4, 2007 | 10:33 AM
QSVeilside's Avatar
Originally Posted by UNR.Grad
Thanks for the link. Tried it out and this drum adjustment works well. Accelerated to 10 mph before yanking the e-brake over and over. E-brake only goes up 5 clicks now, and pedal response increased slightly. Good tip!
Old Apr 4, 2007 | 10:46 AM
QSVeilside's Avatar
I've heard good things about stainless steel brake lines improving response by eliminating the stretch that occurs with the rubber tubes.
Can either go with Goodridge or Russell. Will go with these when I swap my rotors and pads.
Old Apr 4, 2007 | 11:06 AM
seanz0rz's Avatar
Guest
so you dont need to repack the wheel bearings when changing the front rotors? or did i mis read this?
Old Apr 4, 2007 | 11:34 AM
kevin444's Avatar
get the goodridge lines from http://www.hrpworld.com/index.cfm?fo...action=product
best price and awesome customer service make sure you get the 3 line kit and not the 4 since u got a 2000.
Old Apr 4, 2007 | 11:36 AM
  #25
kevin444's Avatar
nope you dont need to. they just slide out with the caliper off.
Old Apr 4, 2007 | 11:56 AM
  #26
MTL_4runner's Avatar
You can't, they are sealed bearings up front.
Old Apr 4, 2007 | 12:41 PM
  #27
QSVeilside's Avatar
Wow, that IS a great price. Only problem is they're out of stock and Goodridge is backordered. Apparently, they'll get more in May. Thanks for the link though.
Old Apr 4, 2007 | 08:09 PM
  #28
johnw999's Avatar
I just changed my front brakes today. I installed new oem pads and autozone rotors. I have 85,000 miles on my 2000 4runner, and the pads really didn't need to be change. I was surprised.
Old Apr 8, 2007 | 07:28 AM
  #29
Ironmike4x4's Avatar
Autozone rotors suck. Mine are already warped and I don't ride too hard on my brakes. I replaced them twice for free with the 2 year warranty and I doubt they will replace them again.
Old Apr 8, 2007 | 12:51 PM
  #30
QSVeilside's Avatar
Just ordered a set of crossdrilled genuine Brembo rotors through DRT. Thought about the crossdrilled/slotted application for a second, then decided to go fully crossdrilled.
The rotors are drilled completely through the rotors with 60 holes as compared with 45 in their drilled/slotted application. Theoretically, that is a significant amount of rotational mass removed off of the blank rotor - Which in addition to the gas/heat venting, should translate to better acceleration, shorter stopping distance, and longer rotor life, (as long as they don't crack). Realistically, these probably provide aesthetics over any noticeable performance difference as compared with the blanks.
Anyways, needed new rotors and thought these were nice. Will weigh them when I get them in for comparison purposes.
Old Apr 10, 2007 | 06:20 PM
  #31
johnw999's Avatar
Yea - once I took the 4runner up to highway speeds, I noticed a vibration when I used the brakes. I couldn't figure out was causing it. I took the wheels off and inspected my work. The new pads and rotors were installed corectly. So, today I asked autozone to replace the rotors that I just bought. I once again took the tires off and installed the replaced rotors. That fixed it. The first set of autozone rotors I bought must have had a flaw. I probably should have gone with brembo rotors.
Old Apr 10, 2007 | 06:26 PM
  #32
fenrisx's Avatar
Whenever I changed the front rotors on my Tacoma .. I'm not sure what brand they were, but they were cheap and from AutoZone..
Not even a month or so later they started to vibrate like the did before... granted not as bad.. but you could tell it was starting again.
I didn't have a lot of cash to drop on rotors at the time though.
Old Apr 10, 2007 | 06:39 PM
  #33
johnw999's Avatar
autozone rotors are cheap, readily available, and have a warranty. That's why they were so tempting. I also helped my brother in law change the brakes on his 99 4runner last month. He wanted to save money, so he used autozone duralast rotors and pads. He has the 15" rotors, so his front brakes were done for just over $60. Cheap, but ...
Old Apr 14, 2007 | 09:41 AM
  #34
dirtypuke's Avatar
i am also having brake warping isues and i think part of the problem is the ceramic pads i got from napa. i read the thread about the performance friction pads and i call auto zone and they said the the part number 5024 was recalled? so i called another auto zone and asked them for the performance friction pads for a 96 land cruiser and they gave me a part number of 0502-20.? will these pads fit and work well on my 98 4wd 4runner?
Old Apr 14, 2007 | 10:23 AM
  #35
BruceTS's Avatar
not to get off the subject too far, but when I did my rear brake shoes, I installed the AutoZone ceramic metallic one's, needless to say, yesterday my brakes went out. When I pulled the rear drum both shoes had no pad left on them. They tore off and I just had a bunch of broken pieces......
Personally I think I'm going back to stock material, it leaves less dust, especially the fronts. The PF pads just make a mess on my rims....
ladybugRC
458
Aug 21, 2020 10:41 AM
Kamaloha
Oct 16, 2015 05:13 PM
the_supernerd
Oct 1, 2015 09:20 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Toys4parts
Sep 26, 2015 01:56 PM
