In need of some desperate help....
Old Sep 9, 2004 | 09:29 PM
FadedSR5Yota's Avatar
Allright I have had a 22re in my 83 P/U for like 3 month's now...replaced many thing's...the thing run's fine untill I got to push on the gas, it just want's to fall on it's face...I took it in to a mechanic and they told me they couldn't figure it out, all the other place's say it will be $90 an hour and they don't even think they wanna look at it...So I am stuck and don't know what to do, just seeing if anyone knew of anyone that could actually have some brain's to figure it out....Thnx for the help!
Old Sep 9, 2004 | 09:41 PM
Nathan Buchanan's Avatar
fuel filter? I dunno, easy enough to replace though. You could have some carb problems too: needle and seat, float maybe. Good luck
Old Sep 9, 2004 | 09:53 PM
Allready replaced fuel filter...and I put a 86 few injected 22re in my truck...isn't carbeurated anymore...
Old Sep 9, 2004 | 09:54 PM
jimbo74's Avatar
are all your lines plumbed correctly?
Old Sep 10, 2004 | 06:56 AM
BT17R's Avatar
Clogged muffler?
Old Sep 10, 2004 | 07:01 AM
TRunner's Avatar
Originally Posted by BT17R
Clogged muffler?
or cat...
Old Sep 10, 2004 | 07:14 AM
Heck, I guess I didn't see the e . How is your timing? When my timing chain jumped a tooth, it really could have been mistaken for a fuel problem. It's probably worth checking anyway.
Old Sep 10, 2004 | 07:23 AM
Nam's Avatar
Nam
Fuel pressure -- need to check!
Air flow meter sensor.
It's also worth to swap out a known good ECU.
Good luck,
Nam
Old Sep 10, 2004 | 12:17 PM
Ya I have done a new fuel filter, afm, tps, tune up, it is getting enough fuel..the only thing is the guy said my timing chain is way off but he can't fix it...so I don't know what to do...I AM mechanically inclined but never worked to much with a timing chain and I don't want to mess anything up...could anyone help?
-Thanks for all the replies!
Old Sep 10, 2004 | 12:33 PM
dajabr's Avatar
Take the electrical connector cable out of the AFM, clean the plug and socket and replace it very firmly. This happened to me when I got my Amsoil air filter, I had pulled this out just enough to disconnect it. You may have grease or dirt stopping the connections or it may not be fully in place.
Old Sep 10, 2004 | 12:38 PM
Cool I will be trying that and I am gonna try my friend's ecu in my truck...I will keep you posted!!!
Old Sep 10, 2004 | 12:58 PM
dajabr's Avatar
If your friend has a 22re, pull the AFM cable out and see if it suddenly behaves the same way. If your dies slowly compared to his with the AFM disconnected then it's likely the timing. You should also check your wiring; since this is a transplant you may have severed one or more of the wires involved.
Old Sep 10, 2004 | 01:23 PM
TRunner's Avatar
Then that is your problem most likely. Grap a Haynes repair manual and get cracking. It will tell you exactly how to do it.
Old Sep 10, 2004 | 02:01 PM
dajabr's Avatar
If you end up doing the timing you might as well put in a conversion kit like this..
http://www.doaracingengines.com/chainguides.html
Old Sep 10, 2004 | 03:02 PM
I did the timing chain on my pickup. It took me like 2 days after school working on it. It's not bad at all. Roger Brown has a great writeup on it: http://www.4crawler.com/4x4/CheapTri...ingChain.shtml . I think the 2 row conversion kit is overkill: It's the plastic guides that break and not the actual chain, and the double row kit is pretty expensive. You could get a replacement kit with metal guides, but I just got one with the regular plastic guides-I figure the first ones lasted 100k miles, these should too.
-Nathan
Old Sep 10, 2004 | 06:57 PM
yotafreakshow's Avatar
Be careful with trying another ecu...in 89 when Toyota updated the EFI, they changed the injector resistance from something like 2 to 11 ohms or vice-versa. I read somewhere if you hook one of those newer computers up to a an older EFI system, the injectors will fry the ecu, like when you bridge an amp and try to run too many subs on it. I could be wrong about that, but I read it on a thread on this site a while back.
Old Sep 10, 2004 | 07:05 PM
here it is: https://www.yotatech.com/forums/f2/i-think-i-finally-fixed-36073/
Old Sep 21, 2004 | 04:32 AM
dajabr's Avatar
Any news?
Old Sep 23, 2004 | 05:16 AM
dajabr's Avatar
Bueller?
Bueller?
Bueller?
Bueller?
Bueller?
Old Sep 29, 2004 | 05:27 AM
dajabr's Avatar
Yo FADE! What's the verdict?!?
jasonty
41
Dec 23, 2018 01:00 PM
mordell
Sep 12, 2015 10:13 AM
kportercpa
Engine Swaps
Sep 10, 2015 12:08 PM
drokkon
Jan 4, 2005 10:50 AM
