Need a little help with Deaver leaf pack install on 2002 Tacoma
Old Nov 30, 2004 | 09:27 PM
P. Bauer's Avatar
2002 Tacoma.
For the life of me, I cannot get the bolt out of the rear shackle (connects shackle to leaf spring). I've already removed the nut and washer, lowered the spare tire, removed the bumper, and hammered on that bolt with a sledge hammer. No dice. Should I just torch it off and buy a new one, or is this not supposed to come off?!?
Thanks guys/gals.
Old Dec 1, 2004 | 09:33 AM
I was wondering how you made out with that bolt and how you lifted the front. I am hopefully going to lift soon and was wondering if you could share some insight and or pics on the process you went through. I think i'm going to use donahos on the front and deavers/bilstens in the rear. Thanks for any input you can give.
Have a good one!
shawn
Old Dec 1, 2004 | 10:01 AM
snowman's Avatar
I wish I could offer some guidance... no luck. But, how much did you pay for the leaf springs and where did you get them?
thanks
snoman
Old Dec 1, 2004 | 08:16 PM
P. Bauer's Avatar
Have a good one!
shawn
I found out that the outer part of the shackle actually is connected to both the top and bottom bolts. So, you must undo both nuts, then tap out the entire shackle just to remove the leaf pack.
I just finished installing the Deavers (1.5" lift). I'm running stock Bilsteins until the Bilstein 5100s arrive (2 weeks).
I also went with the CAmburg 2.5" coilovers up front. But, I only adjusted them up 1".
So far so good.
I would say this install is about a 5 out of 10 on the difficult scale.
Old Dec 1, 2004 | 08:17 PM
P. Bauer's Avatar
thanks
snoman
I ordered everything from Wheelers.com.
CAmburg Coilovers 2.5"
Deaver 1.5" 5-leaf spring leaf packs
Bilstein 5100 Rear Shocks.
Great service, great company
Old Dec 2, 2004 | 10:03 AM
I'm glad that you got it all worked out and thanks for the advice. I plan on doing this soon any advice I can get to make it go a little smoother is always a help. Now how about some pics.
later
Shawn
smthwsn357
May 1, 2024 07:28 AM
rushw
Jul 18, 2015 01:46 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Poncho0206
Jul 10, 2015 06:21 PM
Nickdigg
Jul 7, 2015 06:04 AM
