Need help....
I am looking to remove the factory radio from my 2002 Tacoma. Can anyone tell me/show me pics on how to remove the radio? I have looked at the dash around the radio but I am not sure. I am scared that I will break something on my new truck without some guidance. Thanks!!!
Co-Founder/Administrator
Hello Dan, if the dash is anything like the 3rd gen 4Runners, check out the Tech section here at YotaTech.
There is an article in there on removing a radio, and putting back in an aftermarket unit.
If the dashes are similiar, that article should be of help.
Dan try www.installdr.com They have instructions for most vehicles. If not it's really not all that hard to take Yota dashes apart if you want to just wing it. Good luck.
Try this one:
http://www.customtacos.com/tech/docs...ersheet98-.pdf
It says it is good for up to the 2001 models - and I'm not sure there is much difference with the 2002. So this is probably what you are looking for. I recently did mine and it is pretty easy.
Re: Need help....
Remove the lower dash covering.
One snap connector on each side
Pull the covering to the rear.
Remove the ash tray.
Remove two screws mounted vertically, formerly concealed by the ash tray.
Remove one screw formerly concealed by the lower covering.
Remove two screws formerly covered by the heater panel.
Pull the surround to the rear, starting at the bottom.
One the surround is out of the way, there are four brass screws, two on each side, holding the radio in place. Remove the screws and pull the radio forward.
Originally posted by BajaTaco
Try this one:
Try this one:
Originally posted by WATRD
That PDF is accurate right up to the rear speakers in the XCab. On the 2001's and up, the speaker grill is not removable. So, you have to dismantle all of the plastic trim back there to replace the speakers... It's not a pleasant experience.
I did '01 rear speakers last week...I agree they suck
offroadnutz
Oct 28, 2014 06:03 PM
offroadnutz
Oct 14, 2014 03:19 PM
PAZZO
28
Jun 7, 2012 07:13 AM
