Need Examples of Minor Fender Trimming
Old Sep 20, 2004 | 01:40 PM
MxPx_Reaver's Avatar
'99 Taco w/ 5" of lift. I got 33x12.50x15 on 15x8 rims and they rub a bit with my swaybars on, i expect them to rub a lot with them off. I have already done pinch weld mod and that helped some but I still rub. Im thinking about doing some minor trimming of the fender well. Could i get some examples and pics of this please? Also, I dont want to cut any outwardly visible part of the body. Also, if you have any other ideas to reduce rubbin it would be appreciated.
thanks
Old Sep 20, 2004 | 02:02 PM
HaveBlue's Avatar
5" of lift and they are still rubbing? Where are they rubbing?
I have ~2" lift and 285/75/16s (32.8x11.40/16). I cut away the inner fender near the door and hammered back the pinch weld. I only rub on full compression while performing a left turn.
If you're rubbing, it's probably the plastic inner fender.
Old Sep 20, 2004 | 04:42 PM
U have a 4runner so you don't have to lift it as much. It is hitting when i turn and compress under where the pinch weld is.
Old Sep 21, 2004 | 12:04 PM
Old Sep 21, 2004 | 05:56 PM
/\ /\ /\ |3(_)/\/\|> /\ /\ /\
JonG85
Jan 18, 2023 04:31 PM
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
Flightguy
Oct 2, 2015 05:34 PM
