need emergancy help
Old Jan 29, 2004 | 04:02 PM
need emergancy help
I have a 88' 4runner.
The rear window was not working. when I disconnect the rear wiper, the rear window works. So I know the relay is working. I also know the switch that tells if the top is off is working. ( I bypassed it and everything worked the same).
So I have deduced that the problem lays in the switch that tells if the rear window is up.
Now my question is, where is this switch/relay? and does anyone know a easy way to bypass it? or anyother ideas on what the problem is?
Hep' me please, its an emergancy.
Thanks
Old Jan 29, 2004 | 04:27 PM
Robinhood150's Avatar
http://4crawler.com/4x4/CheapTricks/RearWindow.shtml
Old Jan 29, 2004 | 05:21 PM
Thanks for the help. That is just what I needed!!!
Now could I bother for another quick answer.
My heater fan on the dash is only working in the "off" position, and on "hi" .
Inother words, I can turn the heater to "high" or "off". I knowq it is not the switch (I already tested that), anyone have another idea what it could be?
Thanks again
Kent
Old Jan 29, 2004 | 06:05 PM
AverysDad's Avatar
this guy has tons of info about 4runner repair stuff
Old Jan 29, 2004 | 07:05 PM
toy283's Avatar
It's most likely the resistor. It is located in the passenger side footwell up top on the right side. Right next to the blower fan housing. It's an easy fix and the resistor is readily available at most dealers.
Old Jan 30, 2004 | 05:23 AM
Thanks for all of the help guys. your awesome
Kent
Old Feb 6, 2004 | 06:35 AM
This is why I like this site.
I had a problem, and within 30 minutes, I had the solution. I got a new resistor, and my fan is working perfectly.
Thanks all.
Kent
okamikai
Apr 30, 2018 10:19 PM
Truckwithoutaname
Oct 3, 2015 03:41 PM
Scatterbrain
Sep 3, 2015 06:46 PM
flobadon
Aug 1, 2005 01:39 PM
LSUMatt1514
Aug 2, 2004 02:59 PM
