3rd Gen Drum Brake size
Old Feb 5, 2004 | 08:13 AM
Oakboy's Avatar
Hi all.
First off, thanks to everyone that replied about my diesel question. Learned alot.
My question is with regards to the rear drums on my 99 4runner.
The tire monkey that took my drum off, cracked the drum while he was smashing it loose... suffice it to say, I'm not happy.
I'm looking at going to a wrecker to pick up another one, but I'm just wondering if all the 3rd gens have the same drum size.
Thanks for the info!!
Kevin.
Old Feb 5, 2004 | 09:40 AM
MTL_4runner's Avatar
Look for one with a similar tire size. I believe that all the drums are the same size (although front brakes had 15" and 16" versions to watch out for). By getting them off of a vehicle with the same rim size as yours you will eliminate this as a potential for error.
Old Feb 5, 2004 | 06:51 PM
cubuff4runner's Avatar
All 3rd gens have the same rear rotors. I know this because I was going through a process of converting my brakes so I could fit 15" rims on. Only have to worry about the fronts.
Old Feb 6, 2004 | 03:54 AM
Oakboy's Avatar
Awesome. Thanks for the help guys.
BTW... never have someone try to remove your drums with a 5 lb. mallet..... shesh....:pat:
Old Feb 6, 2004 | 06:54 AM
:pat:
Most drum brakes have a few treaded holes which you can screw long screws into and they will evenly push the drum off.
Old Feb 6, 2004 | 06:56 AM
CTB's Avatar
CTB
Also, make sure your parking brake isn't on.....but I'm sure you already thought of that! :pat:
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
93toyoguy
Aug 2, 2015 07:41 PM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
CanRunner
Jul 20, 2015 01:29 PM
