My Runner is broken!
Old Sep 13, 2004 | 02:31 PM
nolongeraneqaddict's Avatar
It just goes click click click now...
Dont worry, i tried searching but i couldnt find anything under click click click...
So i try and start the car, i can turn the power on, listen to the radio etc, but as soon i try and start it, (turn the key some more) it goes click click click and I lose all power.
Any ideas? Thanks in advance.
90 4runner
3.0
5spd
210k
Old Sep 13, 2004 | 02:34 PM
superduper's Avatar
I had the exact problem with my 98 4runner. It is a starter problem. It may be a quick fix by replacing the solenoids (contacts) inside the starter or you could replace the whole starter which is more expensive.
Old Sep 13, 2004 | 02:35 PM
User 051420's Avatar
Test the battery. If you lose all power after trying to crank it, i bet the problem is a weak battery. If not, it's likely your starter contacts.
Old Sep 13, 2004 | 03:07 PM
Mudfreak's Avatar
Id say almost dead battery
Old Sep 13, 2004 | 03:23 PM
superjoe83's Avatar
or a bad connection at one or both of the battery terminals, take them off and clean them, i bet that will fix your problem
Old Sep 13, 2004 | 03:43 PM
bain's Avatar
i agree....or clean the terminals
Old Sep 13, 2004 | 03:49 PM
Flamedx4's Avatar
Sounds like you need a new key.
Old Sep 13, 2004 | 03:53 PM
colsoncj's Avatar
Another vote for battery or dirty terminals....
Old Sep 13, 2004 | 04:33 PM
The battery is only 4months old or so, and ive cleaned the terminals because ive had that happen before, also i keep them as tight as tight can be. So im going to give the Starters a try in the mornin. Thanks for the help y'all!
Old Sep 13, 2004 | 05:01 PM
transalper's Avatar
Tap the starter with a hammer and see if it'll crank.
Old Sep 13, 2004 | 05:12 PM
I second the hammer (very used tecnique according to Click and Clack of Cartalk)
Old Sep 13, 2004 | 05:47 PM
kevin444's Avatar
Replace the starter contact's. Ive been there and believe me its the starter. My battery was new, when i tried to start the clock would dim because the starter is taking more current to crank and start.
Old Sep 13, 2004 | 08:14 PM
4Hummer's Avatar
Its Hammer time. Oh ohhhh oh ohhh oh..
(Errr sorry that was suppose to be my inner voice...... Come On Don't tell me Im the only one that listened to MC Hammer) <WIGGER YES>
I agree with the stuck starter. My truck does that all the time when I let it sit for to long. (More than two days and all I get it "click click click") whack it with the hammer and she starts right back up.
Old Sep 14, 2004 | 07:36 AM
calg3's Avatar
http://www.4crawler.com/4x4/CheapTri...l#Introduction
Old Sep 14, 2004 | 07:43 AM
Nam's Avatar
Nam
Stuck starter...it happened to my gf's corolla. I thought it was a dead battery, but after I turned the crankshaft a little, it started right up.
nolongeraneqaddict:: before removing the starter, I would test it right there, just be sure to put in park or neutral, connects a 12V positive terminal to the starter solenoid and see if it cranks up.
Good luck,
Nam
MTLroadierunner
Jul 15, 2015 12:58 PM
tpd143
Jul 7, 2015 09:06 AM
musashi86
California SoCal
Jul 7, 2015 03:31 AM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
