My new starter
Old Oct 14, 2004 | 04:59 AM
pickupgirl's Avatar
My new starter
So the starter went out on my truck. Got a new one and put it in a few days later. Now when I start the truck it grinds a little right after it starts up. What is going on??? It appeared to me that I put everything back together right, as it is just a starter, not that much can go wrong... something I missed?
Starter came from Napa and it was a reman
Old Oct 14, 2004 | 09:29 AM
4Crawler's Avatar
Any way you can get your old starter back? Its very easy to repair:
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
If not, pull that starter, open up the solenoid and see what the contacts look like inside. Likely they could be worn or the solenoid plunger could be dirty and either of those will cause the starter to stay engaged for a while after you release the key.
Old Oct 14, 2004 | 06:08 PM
pickupgirl's Avatar
nope starter is gone :cry:
Old Oct 15, 2004 | 03:30 PM
Sludge's Avatar
Sounds like the plunger is not retracting fast enough. You may have some grit or dirt stuck behind the gear or the starter may not be aligned properly. Pull it and try cleaning the unit or just take it back and ask for a replacement.
Old Oct 15, 2004 | 03:33 PM
Cebby's Avatar
Goodie Goodie! I get to do mine this weekend!!!
ladybugRC
458
Aug 21, 2020 10:41 AM
pickle6415
Oct 19, 2015 08:08 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
